Results 1 to 3 of 3
    Reputation: fat_tires_are_fun's Avatar
    May 2013
    1.5 steerer fork question
    Sorry, if this is the wrong section. I would like to know if there is an adapter available to use a 1.5 to 1 1/8 taper fork on a straight 1.5 steerer tube such as the one on my Cannondale. I need to find a replacement for the spongy rst deuce that came on the bike. Logic tells me that since I am reducing the size of a portion there should be an easy way to do this. Thanks
    Reputation: gmats's Avatar
    Apr 2005
    Yes, there are various companies that make adapters and headsets to fit your need. Problem Solvers has all kinds of adapters, Chris King has their De-evolution headset and parts that will adapt your straight 1.5 head tube to a tapered steerer tube.
    A couple good sites to find what you need are Chris King CHRIS KING HEADSETS | Chris King Precision Components
    And Aspire Velotech, just contact them, you can get the right mix of parts to make it work.
    Bicycle Parts Chris King Headsets AVT - Aspire VeloTech - Chris King World's Largest Dealer
    Of course there are other companies like Cane Creek that will be able to put the pieces together.
    Good luck with that, chime back and let us know what you find.
    May 2013
    Going to check these out right now...thanks very much for your response !
  1. Steerer length question
    By 14Stone in forum Niner Bikes
    Last Post: 08-26-2012, 01:52 PM
  2. '12 575 Fork/Steerer Question
    By kayman121 in forum Yeti
    Last Post: 08-09-2012, 05:06 PM
  3. Carbon Steerer Question?
    By bdundee in forum Fat bikes
    Last Post: 02-26-2012, 04:09 AM
  4. Carbon Steerer Question
    By Sizzler in forum Cyclocross
    Last Post: 12-07-2011, 10:39 AM
  5. Quick question about used fork steerer tube length
    By FatTireGoose in forum General Discussion
    Last Post: 07-31-2011, 06:02 AM
