Results 1 to 11 of 11
    Yet another slackset thread...[sorry]
    I currently have a large v2 el guapo, with 1 1/8 forks & Hope headset but I want to fit the slackset headset.
    From what I've gathered, some V2's will accept slacksets, but there were a batch of V2's that weren't manufactured properly and the ream wasnt deep enough [9mm]. My headtube has no lip inside and is smooth all the way through at a diameter of 33mm.
    After thinking this was one of the lucky frames, I ordered the headset for a large frame but its diameter is 43mm.
    a] do i have the wrong frame?
    b] the wrong headset?
    c] am i being thick?
    Reputation: craigstr's Avatar
    Sep 2003
    Pictures?
    Do these help?
    Attached Thumbnails Attached Thumbnails Yet another slackset thread...[sorry]-ht01.jpg
    Sep 2003
    Looks like your frame is a 2010 with a full 1.5" headtube? If so its actually a V1, V2's dont have the cable guides side mounted and have tapered headtubes (1.5" bottom/1 1/8" top). So what you are saying is that the slackset top cup is too small for the top of your frame?
    Its got a straight 1 1/18 headtube, not tapered and the cups dont fit in the top or bottom.
    Attached Thumbnails Attached Thumbnails Yet another slackset thread...[sorry]-screen-shot-2012-09-04-15.41.48.jpg
    Sep 2003
    You have the orignal Guapo. No the slackset wont fit. Sorry, it was hard to tell from the first pics you posted.
    So its a V1 not a V2?? Whats the difference?
    Reputation: terrible's Avatar
    Not even really what everyone considers a v1. The v1 started in 2009. You have what I would call v.1 I belive that is a 2008.
    "I'm the fastest of the slow guys"
    Sep 2003
    So V1 was considered 2009-2010 which had a 1.5" headtube, V2 was 2011 which had a tapered headtube, V3 is the current model. When OnOne took over Titus they named the current model V1 when actually it was V2 because your model was a 2008 which was the first year the Guapo was produced (I believe). Your model has a 1 1/8" headtube and a different front triangle then the the current models. The current model should be V4 but OnOne decided to start the history when they took possesion of the company. A bit confusing I know.
    v.5? v1/2 ?
    Well thats all very disappointing. Thanks for clearing that up. Need to find something else to buy then!
