Results 1 to 6 of 6
    X-Carbon rear suspension lower shock mount play?
    Put my X-Carbon together today. its lovely, pretty light and rides nice, well up and down my road and a few steps!
    I have some play in the rear linkage at the lower shock mount though.
    I thought it was my seat and all sorts but gradually narrowed it down, its not the shock mounting hardware/spacer, there is some play between the mounting bolt and the mounting hardware/bush.
    I'm reluctant to tighten the bolt any further [Is there a recommended torque, I''ll drop On-One a line on that one] but not sure it would resolve the problem anyway.
    I've packed it with grease and the play is now negligible but I cant help think it should be a tighter fit.
    Does anyone else have this, have you ignored it or got in touch with Titus/On-One?
    Cheers
    Found an answer to a FAQ on Titusti website that suggests a small amount of play at the shock mount is normal. True for the x-carbon?
    Also found an answer from Ben suggesting using the Racer x torque settings for the M8 bolt which is 100in/lb.
    Any other info appreciated.
    The Cheater
    Reputation: Veda's Avatar
    Dec 2009
    I haven't encountered this problem on mine but will keep it in mind. Thanks.
    Titux X Carbon 2010 race 9.93kg
    Titux X 2009 "Deore 2012" training 11.55kg
    I dissembled my rear shock yesterday and when I put it back together I had some play in linkage. I solved it by tightening the rear mount bolt, not super hard but pretty firm.
    Yes, solved by torquing to 100in/lb as per spec. Didn't arrive that way!
    Reputation: allenpg's Avatar
    I had the same problem. Pulled out the torque wrench and problem solved!
  1. Blur LT2 Rear shock mount play
    By monty797 in forum Santa Cruz
    Last Post: 03-22-2009, 04:28 PM
  2. Replies: 7
    Last Post: 12-13-2007, 10:25 AM
  3. I need rear shock lower mount for Mongoose Amplifier2,Litespeed,ted wojcik
    By mule2500 in forum Custom Builders & Other Manufacturers
    Last Post: 12-13-2007, 10:23 AM
  4. Replies: 3
    Last Post: 12-11-2007, 10:16 AM
  5. Replies: 0
    Last Post: 12-11-2007, 09:29 AM
