Results 1 to 5 of 5
    Reputation: anvil_den's Avatar
    Nov 2007
    warning: Pic Heavy--Another year with the EG
    Rain not letting up...doesn't look like there's gonna be any ride time for me today...
    ...some pics of what's changed and a few ride shots to sum up 2010 on the EG...
    The "Long" and "Short" -- bar grows longer while crank starts to "shrink"
    Some Remote Upgrade
    Some little shock-DIY...finally finished after 5 months
    What may possibly be the first "RAW" Po1nt Stem mounted... could hardly even find a pic of it on the 50mm anywhere...
    Back with a "Vengeance" for 2011
    Some recent ride pics
    the unlikely "XC" candidates... Me on the EG and Pal on his Puglsey
    ... leading to
    searcher
    Reputation: kovi's Avatar
    Thanks for sharing!
    Unbeatable looking bike, awesome trails. What else do you need?
    Kovi
    Nov 2007
    Hammerschmidt
    and a slightly redesigned rear tri to fit 135 x 12mm TA
    ...I hope the new Titus owners are reading this
    Shock DIY
    What does it do?
    Nov 2007
    Quote Originally Posted by Chris9702l
    What does it do?
    Takes the binding out of the spring. The binding in a smaller shock like this isn't as significant as folks on DH bikes but still it does help....like when taking a turn immediately after a hard drop. The whole rear action is nicely smoothed out
    In my case, it is a little more than that. Am running the enduro needle bearing kit on the lower eyelet with minimal preload on my 400lb spring which can create quite a bit of up/down movement on the spring. The bearing/collar helps keep everything in place. Before, after every few hard rides I have to adjust my lock ring as the spring moves out of place.
    Would be happy to get the Obtainium spacer+bearing kit but was too much of a hassle getting it shipped....thruster bearings used on those and the one here are just standard industrial stuff. Milling the collar was what took awhile...
