Update regarding CCDB Air and "progressive" or "forward" rocker mount position.
The recommendation about the progressive location (forward) by riders in Calderdale was before the CCDB was fitted to bikes, and we've since found that the huge air can on the CCDB doesn't sit well with the rocker shape on the El Guapo. Happily CCDB's are so tunable that you can acheieve exactly the same progression of the airspring with internal shims provided, and the damping circuitry allows for tuning to have exactly the same shock response in the lower rocker mount position. It is possible to run the CCDB in the more progressive position, but the body of the air shock will be marked with very close contact/rubbing on the rocker in certain positions. - See more at:
Titus El Guapo
Titus El Guapo
