    May 2014
    Titus Motolite rear travel adjustment
    Hi, Can someone please guide me as to how to change the travel settings at the rear from 4" to 5"? Mine is set at 4" (bottom hole) and I read that 5" is to have it at the top hole.
    Is it as simple as loosening the screw and setting to the top hole? Are there special tools needed? I would highly appreciate a step by step guide
    IS it just as simple as loosening the torque, slide out and move the fox and the pin to the upper hole?
    any special tools I need aside from troque screw?
    Reputation: TommyB HD's Avatar
    Jan 2015
    You shouldn't need any more tools. Just pay attention to the washers (only 2) in between the shock and frame when you pull the allen bolt out and put them back the same way. May have to tap out the bolt with a hammer. The frame will collapse when you pull the bolt, just lift frame and line up the shock with new holes and replace the bolt. Tighten then ride and recheck for tight again.
    May 2014
    Thanks! Would it be good if I position the bike upside down? or straight up?
    I read (somewhere but not Titus) I need a loctite as well? Is that necessary?
    Jan 2015
    I left the bike on its wheels but either way would be fine. Might even be easier upside down, never tried it that way. If you have extra help around it makes it easier to hold the bike and line the holes up but you can do it alone, just have patience with the washers. If you have blue loctite that would be great but I didn't apply to mine and its never backed out. You need to check all the nuts and bolts from time to time anyway. The bike suspension takes a beating.
  1. Replies: 11
    Last Post: 11-11-2014, 02:28 PM
  2. Carbine 29 rear travel adjustment
    By Jorgebike68 in forum Intense
    Last Post: 12-24-2013, 07:32 AM
  3. Replies: 5
    Last Post: 04-13-2013, 03:26 PM
  4. Rear shock travel adjustment
    By Koin in forum Shocks and Suspension
    Last Post: 05-17-2012, 12:32 PM
  5. talas rear shock travel or length adjustment
    By Dichotomous in forum Shocks and Suspension
    Last Post: 07-28-2011, 10:46 AM
