Results 1 to 26 of 26
    Reputation: veritechy's Avatar
    Titus ML-1 sizing
    Hi,
    I'm new to Titus. I've been a Santa Cruz person.
    I'm about 5'6" and inseam about 30". What size would be be good?
    Would you suggest S or XS?
    Thanks in advance.
    Reputation: Vespasianus's Avatar
    Quote Originally Posted by veritechy
    Hi,
    Thanks in advance.
    How much do you weigh? The small and XS ML use a 1.5" shock, which, if you are heavy, can be difficult to tune. If you could squeeze onto a medium, it would be worth it.
    Weight
    Hi Vespasianus,
    I'm about 155lbs. What do you mean by 1.5" shock? Are you refering to the RP2?
    What size shock does the M use?
    A Superhero Named Tony
    Reputation: McLovin's Avatar
    My wife is 5'1" and rides an XS racer-x. I'm 5'8" and ride a medium. You should probably be deciding between a small and a medium. Run some quick measurements between your existing bike and the Titus (if your current bike fits well), or a similar bike that you have ridden and like.
    Thanks McLovin.
    I just ordered one for $600 - what a great deal for a new'08!
    I got the small. I usually run a medium but it leaves only about 1" margin on the standover.
    How do you like it?
    I'm 5'9, 30" inseam, and the Medium works for me, but feels just a bit big. I think you're right going for the small. I don't have any trouble with the standover, but it feels a bit stretched out. Might have to go to a shorter stem.
    Reputation: xtr444's Avatar
    Hi,
    Thanks in advance.
    Size "S" is about perfect.
    hi Guys,
    I am 5'11" / 180cm and inseam about 80cm, should I get a Medium or Large?
    Quote Originally Posted by one_eye
    hi Guys,
    Yeah, I'd like to know the answer to that one as well.
    call colorado cyclist
    Hi guys, I called colorado cyclist and they suggested a medium for me.
    They have a GREAT deal. $599 for the '08 frame. How can you beat that?
    They got the geometry here:
    http://www.titusti.com/titus09/bikes/trail_motolite.php
    I've had a Blur XC and it seems the top tube length is about 1" longer for the Titus for a medium.
    I emailed Colorado and they recommend a medium for me, I have placed order and is waiting for it to be shipped. Anyway what fork length is this frame design for 120 or 140mm?
    fork size
    Hi One-Eye,
    The guy at Colorado cyclist said the perfect size is the talas 100-140mm.
    I picked up at 80-120mm new reba SL for $298. I'd like a little more travel but at this price...
    Thanks. That's great cos I do have a Talas. I hope Colorado can ship my frame out today.
    just got mine
    and it's sweet.
    It came with the RP23 and a carbon seatpost. What a great buy!
    Hope you get yours soon.
    Sizing for a 6' 200lb rider
    Hi,
    I'm thinking about picking up a ML frame. I'm 6' 200lbs. What frame size do you guys recommend for me? I find that i'm in between a medium and large on a lot of frames...
    Quote Originally Posted by bigguysmallbike
    Hi,
    6' 200lbs also. Medium was way to small. Large is perfect for me. 34" inseem and gorilla like arms.
    bigguysmallbike: Large.
    Any stem length recommendations?
    and it's sweet.
    How is your ML1? Do post some pictures here. Colorado just shipped out my frame today, I am not too pleased with their poor and slow service.
    Reputation: ebeer's Avatar
    I'm 6ft on a large frame. I started out with a 120mm stem, basically trying to copy distance I had on my Stumpjumper (which rides lower and more stretched out...I think more XC - but that's just me). I ended up switching to a 90mm stem on the ML. I much prefer the more upright riding position, and feel I have more stability on the descents.
    YMMV.
    At 6' with a 34" inseem and an arm length of 30", I originally used a 115mm stem. I recentely tried a 85mm stem and like it, but feel it is a little short. 100mm would be perfect in my mind.
    Reputation: anvil_den's Avatar
    Nov 2007
    and generally longer the bar goes nicer with a shorter stem. Or at least thats for me.
    Long bar (690mm) and long stem (110) made me feel like I'm kayaking rather than steering a bike.
    Finally done
    Hi One Eye,
    Sorry took so long to get back to you. I'm finally done. Took a few days to assemble and gather parts...waiting for parts to arrive, etc.
    Here's a pic. She comes in at 28.25 lbs. Kinda heavy, but rides nice. A few things I don't like: Economy is not too great so I swapped out low end parts from my thrasher bike. My Blur has the nice parts...I can always upgrade later, right?
    How's your build coming along?
    Hi One Eye,
    Looks good, i just received my frame today. No RP23 on my frame only a RP2 but I think it is good enough. I will be doing a swap over in the next few weeks.
    You were right
    Quote Originally Posted by Vespasianus
    Hi Vespasianus,
    Man you were right. The rear shock on the small frame is really hard to tune. I've been riding it a few days and I almost always bottom it out and I have about 190lbs of air in it. I like the frame size, but the tuning is tough.
    Thanks for your tip, but I should've listened...
    Reputation: EvilScience's Avatar
    Man you were right. The rear shock on the small frame is really hard to tune. I've been riding it a few days and I almost always bottom it out and I have about 190lbs of air in it. I like the frame size, but the tuning is tough..
    I am in a similar position (5'6", small ML2, ~ 140-145 lbs). It was a toss up for me, but in the end I really felt that the medium was too long for the riding I do. Other may have better suggestions, but I found that running a little less sag (no more than 20%) helped a lot. The problem is that 2mm difference in sag is 5% of the shock stroke, so its a little tough to get just right. Also, with this setup, it is critical to measure sag with all your gear on - camelback, water, etc. I've also had success using a little more sag and leaving the propedal set to 1 for the whole ride. Either way, you probably made the right sizing choice, and once you find the settings that works for you, this bike'll seriously kick some butt.
    Of course, I have also heard good things about PUSH, just a little pricey from Canada.
