Results 1 to 3 of 3
    Titus HCR bottom bracket specs?
    I have a MY2000 HCR, what is the bottom bracket spec? It looks like a 73mm but not sure of the spindle length (113, 118, 121?)? I am using a set of XT M751 cranks (Octalink V2 which means using a Shimano ES-50/51 or ES-70/71 BB will be required).
    Nightriding rules SuperModerator
    Reputation: crisillo's Avatar
    the spindle length will depend more on the crankarms you run and the chainline you want to go for with them.
    Chainline is in the 46-47mm range. I pulled the BB out, what a mess. It is a 73x113. I will drill a drain hole in the bottom to avoid this in the future.
    What a mess!
    This is after vacuuming out 1/4" thick layer of dirt and debris.
    and this is all cleaned up:
