Results 1 to 68 of 68
    New question here. Titus FTM Carbon - Wheelset, Fork, Headset selection
    *I've posted this on BikeRadar to get some UK specific feedback on some of the components, but assume I will get more/different input from actual Titus FTM owners from this forum.
    I'm planning to purchase one of the Titus FTM Carbon frames (large/silver) from On-One but am struggling with some of the component choices so grateful for advice. (I haven't decided on the size yet and waiting for On One to confirm that I can visit their showroom in Roehampton to check out the bikes before I order)
    Forks:
    How much of a difference does the tapered steerer make for the front end?
    Does it matter if I use the XX fork without XX components e.g. is the XLOC remote handlbar mounted and doesn't need SRAM XX brakes/shifters to be mounted?
    I can't decide between
    Revelation RTL Ti Dual Position Air 15mm Maxle Lite (with 1 1/8 inch steerer) 450
    or
    Revelation XX World Cup Dual Position Air 15mm Maxle Lite with tapered 1 1/8 to 1.5 in steerer 599
    Wheelset:
    I think the On One wheelset would be cool to go with the bike Silver/Blue if I got matching blue hub and white rim - but these are new wheels and I'm concerned about durability.
    So it's either
    On One MAX Wheelset 259.99
    Hope Pro 2 Blue hubs with white Stans Crest and DT Rev spokes (~350)
    Superstar Switch Evo blue hubs with white Stans Crest and SAPIM Double Butted spokes (~275)
    Headset:
    I want a Chris King headset but just can't figure out which one goes with the Titus FTM Carbon - is it the inset model 1 1/8 to 1.5?
    Groupset:
    I'll hold off for the 2012 XT to be available and want to run a 2x10 setup. Heard I need to watch the Q factor and keep it around 165.
    Rest of components I'm not too bothered about...
    Thanks for feeddback or other ideas...
    I'd also like to know which headset to go with. The titus page says they use a CK inset.
    Yeah I'm still confused about which headset - especially how to source in the UK.
    Update from Thomas from On-One's website: (commenting on the on one smoothie mixer headset)
    "Sorry guys, you can't use this on an FTM Carbon, thought it will work on the Aluminium FTM. The only headset we know that definately works on an FTM Carbon (as in we have tested it) is an FSA NO.42/CF/ACB which we are trying to source stock of from FSA at the moment. More at http://www.fullspeedahead.com/products/327/025100_NO42CFACB"
    http://on-one.co.uk/i/q/HSOOSMTAPER/...apered-headset
    Hueston Woods Trail Crew
    Reputation: Bikerbob.com's Avatar
    lots of questions
    I may have to move to the UK to help you guys out.
    I mostly use any Cane Creek headset with an i (Italian) after the name. 110, IS81, IS3-1.
    Also FSA Italian.
    The Fox Talas 140 RLC QR15 tapered would be my first choice. I know where to get the OEM version that came with the FTM Carbon. 3 positions, but no remote. $550.
    XX hydraulic is a nice feature and works with any brakes/shifters.
    I would want tapered and thru axle on this bike.
    SRAM has the right Q-factor (166) for the bike. Also has color coordinated drivetrain.
    Bikerbob,
    Would this Pro RMI integrated headset work?
    http://www.pro-bikegear.com/publish/...-PRHS0001.html
    I can't seem to find exact dimensions of it :/
    Also, I can't seem to find much info on the Pro brand, besides it is a Shimano company.
    Thanks,
    /g
    I have one of the FTM carbon frames on order from On One too. I have bought the hope tapered headset for mine I believe this is the correct type for fitting a tapered fork.
    Hi Chris - have a frame on order too - apparently they should have them in the next day or two. As I understand it the hope tapered headset is internal i.e. semi-integrated rather than integrated so may not be suitable. May be worth calling Hope as they may be able to mix and match parts from their integrated headsets instead (or I could be wrong and you may be ok!)
    I have spoken to on one and the FSA Orbit CF40 differentiated headset (FSA CF40 No.42 / 52 ACB headset) will be ok - I've googled it and its widely available although on one will have some in stock soon
    Also I believe from Cane Creek the following combination should be ok - you can order direct from their site...
    http://canecreek.com/component-heads....IS52%20Bottom
    Thanks for the info razz having looked at the info you provided it would seem I do have the wrong one! I have found that Evans Cycles sell the Cane Creek parts suggested so I might get them from there.
    Chris and ridin8ude - what wheels did you go for in the end?
    I've gone for the grey / blue frame so would love to get some of the crank brothers cobalt wheels to match but they are so expensive. may get merlin to build some white ztr arch's wih blue hope hubs instead.
    gone for the talas 150's - arrived yesterday
    merlin also had a great deal on xt groupset a couple of weeks ago so went for that so just need to decide on stem, seatpost and bars - depends if i go down the hope or crank brothers route i think. what have you gone for?
    Chris - good spot on the cane creek stuff - i'll probably go for that too and i went for the planet x fork bung... http://www.planet-x-bikes.co.uk/i/q/...ng-mk-2---11-8
    Well i've also ordered the FTM Carbon in Black and plan on this Spec
    Forks-Rockshox Revelation dual air 120mm -150mm
    Drivetrain - Full Sram XX
    Bars- Monkey Lite Carbon
    Brakes- Hope M4's 160mm Front 140mm Rear (Rotors are Gold but may change to Red or BLack)
    Stem - Hope XC ( Gold but may change to Red or Black )
    Wheelset - Bontrager Rhytham Comp ( will change at later date )
    I'm getting a silver/blue frame in large. I've gone for the following spec:
    Wheels: American Classic Disc tubeless
    Fork: Rockshox Revelation RLT 140mm 15mm thru axle
    Drivetrain: Shimano XT 10 speed with XTR shifters
    Brakes: Shimano XTR trail 180mm rotors front & rear
    Bars: Controltech carbon fibre 710mm width
    I've haven't got the stem and seatpost yet i'm going to buy them when I get the frame so I can accurately gauge what I need - i'm tall so fit is going to be quite important. I'll probably go Thomson for both though.
    The cobalt wheels do look good and they are on offer at Chainreaction at the moment but i've heard that the bearings on earlier models were pretty terrible. The American Classics don't really match the frame with their red hubs but they are very light for the money so I have high hopes for them.
    Madmick that build of yours is going to be super light!
    Dozer
    Reputation: yeahdog31's Avatar
    Quote Originally Posted by chris2407
    Deals can be found on them if you search, especially since CB just unveiled their whole new line at Sea Otter. I really like mine. They seem like an excellent balance of light weight and stiffness. I have heard that the first generation did have some rear hub issues, but I think by now most of those have filtered out of the market.
    Yeah hope it will be pretty light as at this moment in time i have a Trek Ex8 which i'll be stripping down and use most of the parts for the FTM and that weighs in at 27.6 lbs
    Aug 2010
    I've also ordered a medium frame from on-one, most of the parts are stripped from my current bike, a giant trance x2, only the headset and fork are new.
    fork: Fox 32 Talas FIT RLC 150
    headset: FSA Orbit CF-40 ACB
    drivetrain: XTR/XT mix with XT shifters
    brakes: Avid Elixir CR 203/180mm
    wheels: WTB Laserdisc Trail
    dunno about the weight, I'm looking more for durability than an extra-lightweight build.
    Quote Originally Posted by yeahdog31
    Good to hear you've had a good experience with them - it looks like Chain Reaction and ebay look the best bets on price. I saw the new wheels on the Crank Brothers site - some new colours but no doubt no discounts on those for a while. Do you know if there's any way to tell if the wheels are the 1st gen ones? I was looking at the blue ones - not sure if they were available from the start?
    Smile
    Quote Originally Posted by roliK
    i'm sure it will be lighter than the trance anyway. i have a trance 2007 and think its built of lead
    fingers crossed the frames will be here soon
    i have a FTM on order as well i would like to use a non tappered fork.
    can someone help me out my head hurts
    The Cheater
    Reputation: Veda's Avatar
    Dec 2009
    For those who are still wondering. Titus has put up a detailed pdf for choosing the headset for the X Carbon and the FTM:
    http://shop.titusti.com/titus_headse...carbon_FTM.pdf
    Titux X Carbon 2010 race 9.93kg
    Titux X 2009 "Deore 2012" training 11.55kg
    Dozer
    Quote Originally Posted by the_razz
    Blue was the first color available, followed by black and champagne, then the special OEM colors (red, silver, etc.). That said, they kept making blue all the way through, so if you get a used set of blue ones I suppose it's possible to get a 1st gen. set. Not sure if you can identify a 1st gen set without opening the freehub.
    How to tell.
    I am closing out some blue ones. Thye are second generation. You can tell by removing the cassette body. Updated item is hexagonal (octagonal) and does not thread on. ...
    Dozer
    Quote Originally Posted by Bikerbob.com
    Thanks for clarifying, Bob! You rock, dude.
    For anyone who has ordered a FTM Carbon from On-One in the UK before 18th April
    The shipment has arrived and the the lucky one will have it shipped out today.
    I'm one of Lucky few
    Just hope the headset comes soon so i can start to build it up
    thanks - i managed to get some from ebay and the guy confirmed they were the latest production run - will double check when i get them now i know what to check for
    i just got the email saying my frame has been shipped too - so fingers crossed everything else arrives soon
    mines on its way tomorrow as well i am still no closer in the headset stakes using a straigher steerer i don't seem to be able to turn the headset finder into somthing i can buy from
    Quote Originally Posted by LARRYTHELATHE
    I'm with you there! Screw these new fangled headsets! I miss the days of just buying a Chris King no-thread 1 1/8"!
    Here's the bottom part (I think!) based on the pdf (for tapered):
    http://www.pricepoint.com/detail.htm...d=205%20CACIB1
    They don't seem to have the IS42, but I did find this:
    http://www.pricepoint.com/detail/224...5%20CAC4T1.htm
    Can anyone tell me if that top one will work?
    /g
    not sure the bottom will work
    Quote Originally Posted by gateCrasher
    /g
    the top one won't i don't think. it needs to be the is42 which is the "italian standard" not the is41 which is cane creek standard - its is a slightly different size - a mm out but thats enough.
    i got the top and bottom from evans the is42 40 top and the i1s52 40 bottom. for the straight steerer fork i think you need an is52 30mm or i believe you can get the is52 40mm and a spacer.
    let me know if you have trouble finding it on evans - i'll find the links
    @the_razz:
    I can't seem to find the top on Evan's.
    Is this the bottom:
    http://www.evanscycles.com/products/...adset-ec026978
    /g
    Dec 2005
    Hi,
    I will get mine in the next day too. Acros advised me that the Acros Aix26(R) would fit. I will see an report the result here.
    Robert
    @the_razz:
    Is this the bottom:
    /g
    hi - looks like top and bottom sold out at evans
    you need this for the bottom if you have a standard 1.1/8 fork though...
    http://www.evanscycles.com/products/...y=memory%20map
    Could be worth googling for that or contacting evans to see when they may get stock
    this is what you need for the top:
    http://www.nationalcycles.co.uk/cane...p-headset-478/
    Hope that helps
    PS my frame delivered yesterday but nobody in so still waiting
    Well all good here frame arrived yesterday
    Just waiting for headset to arrive so i can get building.
    Attached Thumbnails Attached Thumbnails Titus FTM Carbon - Wheelset, Fork, Headset selection-copy-titus-ftm-002.jpg
    shine carbon, yeah!
    looks good - is the frame as light as you expected?
    apparently mine is in my next door neighbours garage! can't wait to get home to start building it. just waiting for the wheels but may be a little while yet before its all built and ready to ride!
    and in silver and blue...
    Aug 2010
    damn ... me wants! guess I have to wait 'til next week ...
    is this a medium frame?
    its a large - i measured it up and its about the same size as my large giant trance - i'm 6 ft 2 and it should be about right for me - may use an inline seat post and shortish stem
    before anyone gets too excited about actually riding the bike the headtube on mine needs some preparing for the headset to fit as its not completely circular - so may need to take it to a shop to get it done
    Reputation: Pittzer's Avatar
    Never heard of a h/s not being round. Is it normal to have to do this? How do they do it with carbon fiber?
    The frame and rear shock is 2.48kg or 5.27lbs
    Quote Originally Posted by Pittzer
    looks like the inside of the head tube where the headset will sit has been finished off with some aluminium alloy but its just not quite round on my frame - a bit of a bulge at one end - guess i could have got unlucky, guess i could file it down but don't want to mess it up!
    apparently its often the case with new frames, and the headset instructions have this part as step one - so must be fairly common i guess. have only ever replaced headsets in old frames and never had an integrated headset either
    Finally got fed up waiting for On One to put up build kits for the FTM Carbon and took the plunge ordering a large frame. Also ordered the Rock Shox xx world cup as it seems to be a great price even if it is still expensive and picked up their On One Maxle wheelset which just dropped from 259 to 199 squids. (hope the white rims and blue hubs match the frame ok)
    Ordered some super cheap nobby nics from On Ones sale to get me started (hope 2.25's fit ok)
    Ordering canecreek headset from either Wheelie or Evans.
    Then will wait for XT 2012 to be available before I decide what drivetrain and brakes to spring for.
    Now I just need to find a way to hide all the deliveries from the wife...
    Quote Originally Posted by ridin8ude View Post
    Hi just to let you know i ordered the crane creek headset parts for a FTM to use with a 1 1/8 steerer fork with Wheelis and they got intouch saying they wont have them in stock till July
    yeah they told me they won't have the Cane Creek 40 IS52 bottom headset component until August 5th!
    Evan's still has them in stock so going to order there instead...
    i ordered a set direct from cane creek from the USA that was just over 3 weeks ago and still not here
    i was wondering about getting an "uppy-downy" seatpost. anybody else thought about getting one? i'm guessing its not possible to get a handlebar mounted lever as there won't be anywhere to route the cable though so may just get the one with the lever on the post.
    the seat clamp is an odd shape too. presume its because its a carbon frame and it increases the surface area to stop you cracking the frame. if i wasn't going to get a joplin seatpost i prefer a qr but not sure if you can get any in that shape or whether a normal one would be ok?
    ridin8ude - i know what you mean about the parcels continuously arriving - its difficult to hide all the boxes
    my headset has finaly arrived from the US direct from cane creek its finished know, i still need to get a seat and post as i 'borrowed' my wifes from here trance.
    Anyone had a fiddle with rebound on the rockshox it does not seem to have much if any effect in max or min settings?
    it does seem very fast to pedal looking forward to a proper ride tomorrow.
    i think i would like a dropper on the thing.
    i would put up pics if i could figure out how to up load them
    i've got a reverb ready and waiting to be fitted onto the bike.
    @ Larrythelathe how long did you have to wait ??? i've been waiting a while now
    i ordered 17/5/11 arrived sat. it appears cane creek forward the orders they get to dealers that have stock.
    It does not come direct from cane creek if that makes sense.
    larrythelathe - just read on another forum someone reckoned you need a shadow rear mech. did you fit a shadow one or a standard one?
    cheers
    i just used a normal xt mec
    Aug 2010
    Quote Originally Posted by the_razz View Post
    I can't think of a reason why Titus wouldn't ship a QR clamp that fits directly with the frame, you can't use any standardized seat clamp with it. I use a Syntace Superforce on all of my frames, but because of this weird design decision that clamp leaves a 2 cm gap of exposed carbon.
    WTF?
    Quote Originally Posted by LARRYTHELATHE View Post
    Yeah it does make sense as my headset is surposed to be coming from a shop called The Bicycle doctor.
    But might be changing to a tapered set from FSA and change of forks to tapered
    thats the same store that sent mine it came as a letter so no tax
    not sure the taperd fork is worth the money to be honest.
    i may do one day if they do silly prices on them again but i have not seen any 'bargains' for a while
    Titus FTM Carbon
    Titus FTM Carbon, Erm where should I start.
    First port of call should be with the owner / UK importer surely ?
    Me and a m8 got up early and arrived at Planet X after a 30 mile journey at 9.30am sat morning in my landrover, the fact that they owned 2 seperate large warehouses inspired confidence, (first one u come to is closed, th actual showroom is 60' further on but fairly cleary sign posted ) u will see what i mean when u arrive and they seem closed )
    If you are expecting a MTB show room you are totaly wasting your time, and please take this as a positive suggestion ON-ONE, you had NO - zero - aka zip - not one full suspension frame or bike on show.
    Now one engineeer to his credit spent 30 mins trying to find me a frame to look at ( I was interested in a titus X), he could not find one but as luck would have it another customer was bringing in a titus x with what looked like a snapped gear cable.
    The customer allowed me an unsupervised ride on hiis carbon X shame the official factory couldnt do this.
    NB I was so impressed with the ride I ordered a FTM , please wait for the final report of the frame )
    Re the Head set, I gave up trying to find one in the UK that would take a straight fork and I ordered it from Crane Creek in the states, just got shipment notification 3 days after placing the order, fingers crossed it will arrive on time without too much import duty (
    Not sure on the valveing on the FTM, but I had the same issue with a new Rockstar. It seemed really stiff on any setting and even running well below the recommended air pressure. The good news is once you put in a few kms it loosens up and rides wonderfully, just be patient for a bit then you can tweek till your hearts content.
    Dec 2005
    Hi,
    got my Cane Creek but the fitting is a disaster
    Robert
    That would break my f-ing heart. Is it the "oval-ish" shaped head tube?
    Dec 2005
    No, but the cap just not big enough...
    Looks like the H/S is not fully seated. Perhaps you could try the old "heating blanket on the head tube and headset in the freezer for a few minutes trick." That is, if you have a means to pull the headset from the head tube.
    Dec 2005
    Hi!
    I tried a FSA too. Same result. Seems the frame is not OK. Send it back to On-One. Seen what they will say. So the hole build last for 6 weeks. Im really frustrated for going on holiday with my old bike. But I should have known: If you buy cheap you buy twice.
    Robert
    Dec 2005
    Got a feedback from On-One germany today. They say the the CaneCreek is out of the normal dimensions. They will try an Acros. One more week waiting
    Anyone else tried an CaneCreek IS42?
    The Cheater
    Dec 2009
    Quote Originally Posted by Catsoft View Post
    Which FSA? The Orbit? I spend 3 months building each of my bike to ensure I order everything correctly down to the compatibility of the crank shaft length to the frame as I mix parts of different brands. So 6 weeks ain't that bad...
    Dec 2005
    Quote Originally Posted by Veda View Post
    Had an "old" FSA from my prev. Vertex Carbon.
    7 weeks from the order until the start of the project is bad....
    Dec 2005
    Acros is supposed to fit. So they say the frame is allright.
    Nobody used a Cane Creek yet? Ether I got the wrong bearing or the tech sheet is not right....
    Maybe Im spoiled by the Rocky support but it will be definitely my last Titus/On One
    I finally bit the bullet and bought a retail priced cane creek setup. This is disheartening to come in here and see your post of that headset not fitting properly. How did you press it on? Also, can you send the diameters of your headset and the inside diameter of your frame?
    I'll be sure to measure before I press these on. Hopefully all my dimensions are in check.
    /g
    Dec 2005
    There is nothing to press in! The bearings are just dropped in.
  67. #67
    Dec 2005
    Still waiting
  68. #68
    would these go i have sort mine but would be nice to have a faster replacement if i needed one
    http://superstar.tibolts.co.uk/produ...eid=de7ddb064d
