Results 1 to 5 of 5
    Stuck bolt in rear chainstay Titus ml
    Taking apart my 09 ml for some tlc and because the chainstay attachment doesnt seem fluid. Where the stay attaches to the frame there is a long bolt. It comes about 1/2 way out and then just spins. Actually more like a clunking as I turned the bolt it will go back in fine but if I try to back it out again it hits a certain point and won't come further.
    My first time trying to remove so who knows. I plan on calling Titus tomorrow but figured I would give this a shot first. Hopefully fixable because I still have a place for the ml.
    Best,
    Patrick
    Reputation: anvil_den's Avatar
    Nov 2007
    Thats the main pivot pin... you probably just hit the point where the thing is caught at the washer between bearings... either pull up as u wind the bolt out or give it a little tap with blunt punch and a mallet (from the other end where it is being unwinded from). sometime a little wiggling of the 2 triangle will help to dislodge...
    I have had the same problem with all of my m/l's (ti & alum), ftm's (carbon & alum) and racer x's. I use a wooden dowel that is just alittle bit smaller than the thru pivot bolt. Just tap gently and it will come. Sometimes the bearing comes out with the bolt.
    Thanks for the replies. I ended up using a bolt about the same size and tapped it out. Now I just need to get the bearings out.
    Rent a blind puller from the auto store. Should be free. Tension up the bearing tap, don't use the puller/hammer bar. Use a punch to tap it out from the opposite side. Brace the frame on some 2x4 pieces to provide a soft backing for the frame and the height clearance needed to get the bearing out.
  1. Help with a stuck allen bolt.
    By bcon in forum Frame Building
    Last Post: 05-14-2012, 07:07 AM
  2. Otero seatstay/chainstay bushing/bolt
    By 8valvegrowl in forum Mongoose-Schwinn
    Last Post: 02-28-2012, 01:32 PM
  3. Broken bolt stuck in frame! Please help!
    By TheAllCreator in forum General Discussion
    Last Post: 03-27-2011, 09:46 AM
  4. Rear Derailleur Pivot Bolt Stuck
    By jtmartino in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 01-18-2011, 05:16 PM
  5. [Very] Stuck Shock Bolt - Yeti 575
    By KPH in forum Yeti
    Last Post: 12-30-2010, 12:54 PM
