I am mid-build on my rx and I have two problems. I was planning on using a SRAM X-Gen front deraileur and the weld for the cross link seems to prevent it from being mounted in the right place so that it will clear the big chain ring. Is this a known problem, or am I missing something really obvious?
The second is that I am running tubeless and the lbs recommended Geax 2.3 (which they said runs pretty small, like a 2.17), which do fit but barely. I am thinking of trying to take it back for a 2.1, but am not sure they will take it back after it is mounted and Stan'd. Has anyone run this large a tire on a 2005 RX. It is pretty tight, but I probably have 3/8th inch clearance from the chain stays. I would prefer to not have chain stay rubbing and just deal with it now. Any thoughts?
