    Reputation: honkeystyle's Avatar
    Sightly confused on what headset to get
    Snagged up the new El Guapo and am looking to buy a headset for it, but there seems to be about 3154^8 options. To make sure I at least as going in the right direction..the headtube is tapered, I am running a fork with a tapered steerer tube so the head set needs a top with od of 44mm and Id of 1.125in and the bottom needs an od of 49.6mm and id of 1.5 in? (sorry for the units jump around). I am at least venturing in the correct direction aren't I? I'll worry about attacking the whole stacking thing and how internal and external affect the ride later...
    thank you!
    Reputation: craigstr's Avatar
    Sep 2003
    No problem, with a tapered fork I'm pretty sure you cant use a lower internal cup.
