Results 1 to 8 of 8
    Dec 2004
    RX80 vs RX 100 new/old geometry
    Does the 2003 RX have different geometries than the 2005, or the RX80 vs the 100? I ask because I was at my LBS the other day and the guy pulled down a medium and the TT length measured a lot shorter than the standard spec (like 22.8). The HT and ST measured out ok for a medium, so I started thinking that something was not right. I checked out the SN and it was an 2003 model, and the guy wasn't sure if it was a 80 or 100 mm frame. I am thinking it may have been an 80 because of the different geometry of the TT, but does anyone have any ideas?
    Let's ride
    Reputation: rensho's Avatar
    The TT of the rx100 is longer than the 80 for sure.
    I went from a 80->100 and didn't realize the bike was now bigger. Lucky for me, it still fit well.
    I know for size small, a 2003 RX 80 has virtually identical geometry to a small 2005 RX 100. I know because I had cut and pasted the geometry information at one point into an Excel file. I found the data again, but only in Excel and used that in my purchasing decision for a 2006 Motolite. I don't have the information on the medium anymore -- sorry.
    Let's ride
    Good point, i should be specific. Mine was a 2001 small rx80 -> 2004 small rx100. The TT was about 0.5" longer, rx100.
    Reputation: xl_cheese's Avatar
    Make sure you measure effective TT. the top tube is lower on the 100's.
    ... I was going to post a link to titus' website, but it's down.
    Dec 2004
    Titus confirmation
    I spoke to Gus at Titus and he confirmed that the 03 RX80 has a shorter TT (both med and small), as noted in the above posts. The 80 small has a 22.2" TT, and the 80 med is 22.8" (I think that is what he said). The guy at the shop was "guaranteeing" that it was a 100, but Gus mentioned that the 100 didn't even come out until 2004 (something I didn't realize), so there is no way it was a 100.http://forums.mtbr.com/images/smilies/nono.gif
    Reputation: sungchang's Avatar
    Quote Originally Posted by Santa Fe NotsoSlim
    For 03 model there was no RX80 nor RX100 distinction as there was only Racer-X (designed for 80mm). I have a Medium 03 RX which I believe has ETT of 23".
    I was measuring the top tube on my 2003 RX (supposed to be 100) and I also measure around 22.8". I thought it was a bit on the short side for a medium. The head tube is 4" so I can't say I got a small size frame.
