Results 1 to 6 of 6
    And if not, why not?
    Roll call! shock and fork set up database!
    We already have a set up sticky thread, but the most helpfull info is missing from most posts. So lets have it. Give us your weight, what bike you ride, and what kind of rider you are, and then tell us what your suspension setting are. I'll styart I'm a 34 Y.O. expert xc racer with a carbon RX, and I'm running 100lbs in the rp23, and 79 in the fox 100 rlc fork. The fork is right in the middle on rebound, and the shock is only two or three clicks in. I'm happy with my fork setting, but still unsure of the rear, and the front end tends to drop when i leave the ground, which is no good.
    campmor.com
    new york/new jersey xc race series:
    http://www.campmor.com/html/h2h.shtml
    Quote Originally Posted by guava
    How much do you weigh?
    Oops!
    about 154 lbs
    campmor.com
    thats right living legend
    Reputation: blackagness's Avatar
    Mar 2005
    The front end's not going to lift it's self.
    "El Whatever"
    Reputation: Warp's Avatar
    Here I go...
    Bike: Switchblade TALAS Frame 2004, 5" travel Rockers, Medium Size
    Rider Weight: 145 pounds
    FORK
    Fork: Marzocchi All Mountain 1 2005, 130mm-150mm
    Travel Setting: 145-130mm
    Sag: 25%
    Spring Rate (Heavy, Medium, etc): Stock on ETA
    Air Preload: 15 pump strokes
    Positive Air: N/A
    Negative Air: N/A
    End of travel Pressure: N/A
    Compression: Always at "DS"
    Threshold: N/A
    Hi-Speed Compression: N/A
    Low Speed Compression: N/A
    SPV Pressure: N/A
    Rebound: 4 Clicks from Full-Open
    Oil Levels: ETA Side 40mm from top of crown, TST Semibath 40ml.
    Oil Weights: ETA + Semibath 10wt oil, TST 5wt oil. All oils Yamaha Yamalube Fork Oil.
    SHOCK
    Brand / Model: Flox Float R 2005
    Eye to Eye/Stroke: 7.875" X 2"
    Spring Rate: N/A
    Air Pressure: 135psi
    Sag: 27%
    Positive Pressure: N/A
    Negative Pressure: N/A
    Compression: N/A
    Low-Speed Compression: N/A
    Rebound: 4 Clicks from full open
    Hi-Speed Rebound: N/A
    Low-Speed Rebound: N/A
    SPV Pressure: N/A
    Boost Valve: N/A
    Volume Adjuster: N/A
    Check my Site
    Chilling out
    Reputation: bear's Avatar
    '03 Quasi-Moto, 5.9" travel config, est 35# as built
    Rider 225 bear-nekkid
    Fork: '07 Marzocchi 66 SL1 ATA, 140-180mm travel (175 in truth...)
    - 100 psi PAR, 50 psi SFA, 0 psi RC2
    - rebound centered
    - compression centered
    - oil as-shipped
    - sag 25% rider-only
    Shox: '07 Marzocchi Roco TST R
    - 700# steel coil (note that frame gives 3:1 leverage ratio)
    - bottom-out chamber as-shipped (don't know psi, will post when I have it)
    - rebound centered
    - TST in DS, but not yet trail-proven so future is undecided
    yes, I setup my sag a little "lean" so that when I have gear on it'll be betwixt 25- and 30%
    The Roco replaced an '03 Vanilla RC coil that really showed it's age once the 66SL was mounted. Totally an unproven quantity on the Quasi at the moment, but I'm optimistic based upon bouncing around the neighbor's yards and such. I really need a back yard like Evil Patrick though, then I'd know for sure.
