Results 1 to 75 of 75
Thread: Roco-Lite
    Reputation: titusquasi's Avatar
    Roco-Lite
    I have crossed over to the Dark Side. Where my flashy RP23 w/ HV Sleeve previously resided now lies a black serpent waiting to strike.
    Sorry for the drama, all. The RP is on its way back to Fox for their second attempt to fix the oil leak coming from the rebound/propedal adjusters. I was really liking that shock with the HV Sleeve and was just about to experiment with reducing the volume to create the exact spring curve I want when the thing started squaking like a cage full of monkeys on banana day. No oil in the damper and the shaft got hot after about 20 seconds of use.
    Anywhoo...I'm on the way to Moab in a week and found a deal on the Roco Air R for $137! For that price I can just keep it for a spare if I don't like it. I've only had one ride on it so far and this is what I've got for ya':
    WEIGHT: I was in such a hurry to send the RP to Fox and get the Roco Air on the ML that I forgot to get weights. I'll get that when the RP comes back. I can tell you that the Roco Air is a hunk of metal--it's solid. By Marzocchi's and Fox's weights it's right between the RP and the DHXA. It added at least 1/4 to 1/3 lb to my bike weight (again, I appologize for not having a "before" weight on the bike, just a vague recollection).
    PSI: At 235lb on a size large ML I was running 170-175psi in the RP23 with standard sleeve for about 30% sag, 195-200psi with the HV sleeve for about 25% sag, and am currently around 125psi on the Roco Air for around 30% sag.
    OBSERVATIONS: The Roco Air is definantly made for big drops and hard runnin'. It is very smooth in the first half of the stroke (seals are breaking in so it got better by the end of the ride) and then will ramp up at the end. It never feels harsh but it won't give up full travel easily. At 30% sag I was doing 4' drops to flat ground and intentionally landing with my weight over the rear and was only using 1 3/4" of the 2" stroke. Back home i dropped the psi to 50 and bounced around to try and bottom it. I got 1 7/8" by doing this but could not get a full 2" no matter how hard I slammed it (this was the same on the RP as it would hit a small rubber ring on the damper shaft at 1 7/8"--a safety net I assume). The RP23 with the HV sleeve would literally swallow bumps and make them feel like pebbles but would use full stroke on many obstacles. The RP23 with the standard sleeve was harsh in the midrange travel but would take bigger drops better but i could never get it to use full travel without ridiculous sag. The Roco Air seems to swallow bumps almost as good as the RP/HV combo but apparently has some bottom out protection system in place. I don't know if it's hydraulic or a bumper but I got the feeling that this thing will take a lot more hang time than I would ever consider. If you're gravity oriented, I'd say this is certainly an option to consider. I do wonder if there is a way to decrease the bottom out resistance as I'd like to use more travel--anyone know how this shock works?
    FM
    FM is offline
    Reputation: FM's Avatar
    Apr 2003
    Nice review! Sounds like a great option....
    Nightriding rules SuperModerator
    Reputation: crisillo's Avatar
    Nice!
    what's that rattle?
    Reputation: Blofeld's Avatar
    Bottom Out Resistance
    It sounds like you've really put the Roco through it's paces. Certainly a handy item to have in the toolbox if the stock Fox explodes!!
    I've never played with a Roco, but since you're getting less travel with more positive air pressure it doesn't sound like it uses a bumper. The Marzocchi site mentions "Fixed Negative Air" as one of the shock's features. In comparison, the FLOAT sets the negative spring pressure automatically using a port from the positive spring chamber. For Marzocchi forks with a negative air spring, apparently one of the functions of changing the pressure is "regulating the travel maximum value in a range corresponding to 20 mm." This makes me believe that you might be able to get more travel from the Roco by lowering the negative air pressure. I don't know if this is something that would have to be done at the factory or not - you could always roll up to 3000m, reset your positive pressure, find some drops, and re-test the travel!
    Goin' Down ain't bad!!!
    Reputation: Dropin%Dug's Avatar
    Mar 2006
    What settings does the knob give ya...lockout, platform, full plush? How well does it work? I'm running a Push RP23 on the RX and I pretty much leave it in #2 engaged. Occasionally I'll turn it off, but was wondering how you felt about the Rocco Adjustments.
    Looks like a nice piece of hardware....always was a Zoch Fan.
    Dug-da-Goat
    "Oh momma, could this really be the end? To be stuck outside of Mojo with the High Side Blues again!!!"
    Trophy Husband
    Reputation: geolover's Avatar
    Quote Originally Posted by Dropin%Dug
    I believe the knob is rebound adjustment. No other adjustments other than air spring.
    Extreme stationary biker.
    "El Whatever"
    Reputation: Warp's Avatar
    Great info, bro!!!
    Wanna know what's up with the bottom out??
    Simple, undo the canister and see what's on the shaft... by your comments, I'd say small air chamber or a big bumper (just like a coil shock).
    You tried drops and just bounces to bottom it, should it be damping, you would have bottomed on one or the other, I think.
    It could be more compression damping with a lower spring rate, though.
    Anyway... seems like what we've been looking for since a long time... An air spring shock, with plush feeling but at the same big hit capabilities.
    I wonder how many pressure should my skinny arse would need at 150-155 fully soaked wet.
    Check my Site
    Mar 2006
    The more I look the more I get confused.
    Uhmmm seems to run lower air pressure which IMHO is a good thing (Sensitivity, etc). Never did like the idea of the Scott Ransom and its 400psi Shock It's also one of the reasons I'm excited about Brent's 2:1 Air Curnutt, which supposedly will run about 80psi spring pressure.
    This must be because the Rocco has a larger piston than the RP23 which it looks like it does. What confuses me a bit is that Quasi said he was running HIGHER air pressure in the HV Sleeve for the RP23. Dunno, but it sounds like it's pretty stout if he's dropping 4' with it.
    I'm a little confused about the Platform. It doesn't sound like it's really adjustable. I wonder if the "Negative Spring" is influenced by the Positive pressure and impacts the platform? From what Quasi describes it doesn't sound like it has an independent platform air adjust setting. If increasing the spring pressure increases the platform but does away with travel and stiffens the damping, then that flat out sucks in my book.
    And there isn't any On/Off switch like the RP23 which isn't that big a deal. But not being able to dial in a platform to me is a little strange. Yeah, Fox only has three settings, but at least you have those as options and you can always get it tuned to your liking by Push. Yeah, I guess you can also send them a Rocco to tune, but it just seems a little limited.
    Confusing shock this Air Rocco....
    Dug-da-Goat
    Yeah, the knob is simply rebound. When I got the shock the rebound was set at full-slow and it felt about right on the bike. Then I noticed that adjusting the knob made no difference in rebound speed. I began unscrewing and apparently there is no positive stop at full-fast or you can turn it past the stop. I backed it out 25 clicks and it never hit a stop (I didn't go any farther for fear of messing something up). Took it out for the first ride and fiddled with the rebound mid-ride and it was now creating an adjustment range from superfast at 20 clicks out to slower than molasses in Decmeber at full slow. It was like something was sticking and began working during the ride. I'm currently running at 6 clicks out.
    Trophy Husband
    D Dug
    No platform on this shock. Just plushy/active goodness.
    This shock might not be great for a single pivot.
    The Roco Air has NO platform--just the way I like it! I'm not sure how the negative spring works but the only adjustments are air spring pressure and rebound.
    Adjusting the air spring pressure in my typical sag range (25-30%) appeared to have little effect on the bottom out progression (I used about the same amount of travel no matter the pressure). At much lower pressures it is easier to force the shock into the last 1/4" of its travel but it seems to create some extra resistance at about the same point no matter what the air pressure. This leads me to believe that there is either a hydraulic or mechanical (bumper) bottom out feature that makes this shock big-drop worthy. If it's a bumper there is no perceptible transisiton point.
    I weigh about 245lb ready to ride with the CamelBak full and on a 4' drop this thing wasn't even breathing hard. It just sucked up the landing like I had ridden off a curb. The funny thing is, even though it doesn't provide full travel it never feels short from the saddle. The ride is very smooth and controlled. I plan to contact Marzocchi to do some investigating on whether or not I can adjust the bottom out progression. Ultimately I think it will end up on my QuasiMoto where the 3:1 leverage ratio should make better use of the entire travel.
    HOLD THE PHONE! I just got off the phone with a tech man at Marzocchi USA and he explained something to me that I have not heard anyone else say about this shock. It has a "fixed" negative spring but coupled to this function is an adjustable bottom out resistance.
    Look at the picture of the shock. The body consists of three "visual" sections--the upper section is black and has the sticker on it...below that is the machined aluminum section...below that is the lower black section. This lowest black section unscrews from the machined aluminum section to reveal a rubber o-ring on a floating aluminum carrier. By unthreading this lower section and thus freeing the o-ring you can then thread it back on at various eye-to-eye lengths thus creating different air pressures (I think the tech actually said vacuum not pressure) in a small secondary air chamber on the very exterior circumference of the shock body thus changing the negative air pressure and thus changing the bottom out resistance.
    The tech said this creates more or less "negative vacuum" which affects negative air pressure and bottom out resistance. I had a hard time following his explanation but the bottom line is that if you thread this piece on at max shock compression you get max bottom out resistance (this is the factory setting)...if you thread it on at max extension you get the least bottom out resistance. It is then variable at any eye-to-eye length in between. This seems very cool to me and I'm quite excited to experiment with this function in the days ahead. Stay tuned!
    thats right living legend
    Reputation: blackagness's Avatar
    Mar 2005
    If it doesn't feel bad, and isn't getting full travel, that's a good thing... No? Leave it be.
    Did you get to try it at any high speed stuff?
    "El Whatever"
    Quote Originally Posted by titusquasi
    Wow!!
    That makes sense... Something similar occured with the "Iso-Lite" cushion from Rock Shox... but the ways to deal with it are different.
    RS claims the different Iso-Lite Cushion elastomer changes the bottom out characteristics of the shock. I couldn't see how would it be as the IL elastomer is on the opposite side of the "bottom out" side, so to speak.
    I had a discussion with Jason from Sicklines (killing cool dude to deal with!) about it... and we kinda couldn't figure it out why RS made such a claim.
    Now the explanation from Marz tech explains why.
    Cool! With the sick low pressures I'd have to use, beng able to neglect the negative spring is very nice!!!
    There'll be a Fox Float R for sale soon, I think!!
    Check my Site
    "El Whatever"
    Titusquasi...
    Got a chance to ask if it's really user serviceable like the Roco Coil???
    On the pics at Zoke's website, you can see there's an inflation port just like in a Fox. That would mean it's nitrogen filled and hence, not really user serviceable.
    Thanks for any info on that.
    Check my Site
    moto lite or quasi moto
    titusquasi, how does the moto lite compare to your quasi, which do you like better?
    Quote Originally Posted by Warp
    Titusquasi...
    I don't know about a nitrogen charge. The Marzy tech guy just said that they would be posting a service video that would detail all the maintenance you can do at home including the procedure for adjusting this "secondary air chamber". Apparently the shock I got is hot off the assembly line as the tech was supprised to hear my description of the shock indicating it was a last minute change that had just been made a couple of weeks earlier. Where did you find schematics detailing the internals of the Roco Air?
    Wow!!
    My assumption is that by setting the secondary chamber at full shock extension the negative pressure is at its max and bottom out resistance is at the minimum...and vice versa. This makes for a very supple stroke with a linear spring curve (per the Marzy tech). Sounds to be perfect for you feather weights!
    With the revelation of this adjustable bottom out resistance, this shock may have found a permanent home on the ML and its twin may be on the Quasi in about a week!
    I was just foolin' around in the yard after setting the secondary spring at max extension (high negative air/ low bottom resistance) and the initial stroke does seem to be even smoother (if that's possible, and apparently it is)--like butter on hot toast. It's been awhile since I've been on a good coil shock but this feels pretty darn plush.
    Also, I can now force the shock to reach just a hair under 2" stroke by using low air pressure and a hard bounce. Before under similar pressure with the factory setting of max bottom resistance, I could only get 1 3/4" (1 13/16" if I really slammed it). Soooo...the adjustment does seem to affect bottoming resistance. More when I get some saddle time in.
    Quote Originally Posted by blackagness
    Good point but if I'm hitting a 4' drop with my weight hard on the saddle I want that to be a max travel moment. As I recently found out, I can now adjust this--awesome!
    High speed work on the one ride I've been on was excellent. Very little kick back on rapid fire hits and I expect this to get better by changing the secondary chamber pressure to create more negative pressure and less bottom resistance (should make the initial stroke more supple and the stroke more linear).
    Quote Originally Posted by Big boss man
    The way I see it, I've had the ML long enough that the "new" has worn off and which ever bike gets ridden the most is my favorite. I have long been a Quasi fan and I'm almost sad to say that it collects dust most of the time.
    The ML is simply more versatile. The frame weighs about 1.5lb less so with equal builds that's a decent difference. There's something more, the ML feels quicker and faster--I can't put a finger on it but there is a difference.
    I take the Quasi out when I want to just plant my rear in the saddle and let 6" of travel eat up anything in my path--I'm not out to be fast just to have some fun.
    I take the ML when I want to be ready for anything. Hit it hard and fast? No problem. Double back on the fun stuff to take a bigger drop? Bring it on. Crazy steep climbs? Gimme' more. Put in the miles to work the cardio? No sweat. The ML is like a Racer-X and the QuasiMoto rolled into one--I love it!
    Honestly, I'd sell the Quasi if I thought I could get decent money (which I can't) and if I didn't get ridiculously sentimentally attached to my bikes (which I do). She's a part of my life and will someday hang on the rec room wall when something irreplaceable breaks.
    Dec 2005
    Thanks titusquasi !~! Super Luper post dood
    I ordered my Roco R earlier this week. Due to my frugalness it was sent international air post .... that means maybe two more weeks until I see it down here.
    It is good news that you can get an air shock with no constipation and a big piston !~!
    Soon, you can even send it to PUSH for the new piston
    Mine was $137 and this is the photo from seller's website:
    Don't know if mine will have adjustable bottom out ?~?
    I got it out of curiosity due to shimmed damping and no constipation... and since sending my DHX C to PUSH is a two month ordeal from here I would get a spare shock. Maybe I will be sending the Roco R instead
    Gotta go eat my burger now ....
    Quote Originally Posted by All Mountain
    That website looks strangely familiar. Except I had another retailer that starts with a "J" price match it so I have a month to order one for the Quasi in the event the original site changes the price!
    Do elaborate on PUSH working on this shock. Is this a know fact? (I haven't been keeping tabs on the Suspension Board.)
    Your shock will have this adjustable bottom resistance/ negative air feature. They all do. In that pic you posted you can see some ports around the lower portion of the black section where the shaft inserts into the body (that came out sounding a bit inappropriate ). Those ports are there so you can use some sort of c-clip removal tool or similiar item to facilitate the installation and removal of this removable piece (much like removing the bb cups on the external bottom brackets). I found that as long as you can get a good grip on the piece you can remove it by hand.
    Anywhoo...you remove this piece and it frees up a carrier that is holding an o-ring that is actually holding the pressure. You don't have to remove all the pressure in the shock but the Marzy tech suggested I do this to make it easy to position the shock anywhere in its travel. This is where my understanding of this function ceases. All I know is that if you recap the removable piece at full shock compression you get max bottom resistance (and least negative pressure--he didn't say this but it is just my assumption--I'm probably wrong...this is the factory setting). If you recap this piece at full shock extension you get minimum bottom resistance (and I assume max negative spring to make a super supple initial stroke). The function is variable anywhere inbetween--you just have to be able to hold the shock static while you put the piece back on to be able to create a repeatable measurement.
    I have set the chamber at max extension to try and use more travel on the bigger hits. I've just done some plunking around in the driveway but I believe the shock does feel more supple in the initial stroke (which is what is supporting my assumption that this setting creates max negative air spring). The shock does seem more linear as you get into the meat of the stroke but there is still some bottom resistance in place.
    On the RP23with the HV sleeve I could set sag at 25% and bottom it by slamming down hard while hopping around the yard. On the Roco Air with the bottom resistance set to a minimum I can't make the shock bottom while doing this set at 30% sag. This shows me there is still some progression at the end of the stroke even when set at minimum bottom resistance.
    Bottom line is I'd bet a dollar you're going to love this shock. The seals will break in so give it time. I've only been on it an hour and it is noticeably smoother (and I don't see how it could get any better). The Roco Air feels like the RP/HV combo but with super smooth damping action and a progressive end stroke that creates a bottomless feel. With the RP/HV combo it felt like a pillow until it abruptly hit bottom. With the Roco Air it feels like a pillow that ramps up so smoothly that the 4' drop behind you felt like landing a curb drop. I don't think you can make an air shock feel more like a coil than this does--it really is incredible how supple this thing is. It keeps the rear tire tracking the ground as if it were attached with velcro! I think I'm loving Marzocchi!
    Mar 2005
    Great thread and post's TQ! I hope you post more often.... Thanks!
    Reputation: wormvine's Avatar
    TitusQuasi!
    I wanted to maybe clarify something, maybe. I have been working on my 07' 66sl trying to get the negative air chamber adjusted to fit my proper main air pressure.
    By compressing the shock with the negative chamber open, I believe you change the initial neg chamber volume. When you pump back up the shock, the negative chamber pressure self adjusts to match the main air pressure. So if there is 100psi in the main chamber there is 100 psi in the negative chamber. The only difference now is that your negative chamber volume is larger or smaller. When this chamber compresses, the volume dictates the progressivity of resistance, hence a smaller neg volume would have stronger bottom out resistance.
    I am glad someone found out the ROCO AIR has the ability to adjust the neg chamber volume. It's good to know...
    My 66 has a little different design cause it has a separate bottom out chamber but I believe the neg chamber volume concept is the same
    Mar 2005
    Quote Originally Posted by wormvine
    TitusQuasi!
    My 07 AM1 SL does pretty much the same thing, if I understand you correctly?
    TitusQuasi!
    That concept makes sense to me but I didn't have the tech try to explain how it worked I just had him tell me how to adjust it. He was very patient and understanding, some of the best customer service I've had anywhere.
    It probably does work similarly. The only difference would be the TST-5 cartridge.
    I have been tearing my ATA cartridge apart trying to solve a possible issue with preload.
    From what I have read and now believe...
    You can set the neg chamber volume similar to the same way you can set the ROCO air.
    Fact, The Positive Air chamber pressure should always be the same as the negative pressure because when you fill up the pos chamber it expands and compresses the the negative chamber till they reach equilibrium. (ie. the same psi on both sides).
    What I am trying to fix is a condition known as ATA preload. The piston between the POS and Neg chambers is part of the main shaft. When you fill up the pos chamber the piston is forced to extend out of the cartridge as it tries to equalize with the negative chamber. If the negative chamber is not set correctly the main shaft reaches topout before the negative chamber pressure can equalize with the POS chamber. This will result in a neg chamber pressure that is lower(how much I don't know), than the POS chamber pressure. This results in less supple movement.
    The function of neg air, IMO, is to create counter pressure so that stiction is minimal and to increase small bump sensitivity.. If negative air exceeded pos air pressure travel would start to reduce.
    On my Pike 454, I can set the negative air with a pump. If I pump it up too much, I loose travel.
    Since there is minimal need to have neg chamber pressure exceed pos pressure, Marz's system is great in that it sets the neg chamber automatically.
    Unless it is set wrong from the factory and causes preload.
    After all this I would much rather have a valve on the neg chamber and set bottom out some other way.
    Well I dont think the ATA cart works this way. If you notice in the ata cart inside there is bleed port from pos to neg this will instantly equalize both chambers and then once you pass this port you are compressing the pos air and creating less press possibly up to vacuum on the neg side, so neg volume really cant be adjusted because this port is at a fixed location on the cart body, but no big deal this is way you have par for bottom out. The rocco air is prob works in that if you start the neg with more volume it will have more pressure once the shock is at full extension making it more plush and more linear, if you start with less vol then it will reach vacuum sooner and resist bottom out.
    Mar 2005
    Quote Originally Posted by Jesse Hill
    My AM1 SL seems to really suck once equalized which no matter what alway's comes back to 100/100? or something around there which is followed by a harsh clunk that makes the whole thing feel like a big rigid, harsh piece of poo.
    Dec 2005
    The Squeaky Wheel says PUSH will work on this shock
    I'm busting to get this beauty... it's going to look so good on my ML (and a good match for my fork as well ) !~!
    So the stock configuration provides the most bottom out and it gets cushier thereafter....
    "El Whatever"
    Titusquasi... Can you please measure how far from the eyelet center is the widest part of the shock??
    I just discovered that depending on how far the widest part is from the center of eyelet, it may not fit my Switchblade....
    At 52.35mm wide, I would have only 2mm clearance if the widest part is as far from the eyelet as it's the Fox Float I'm running now. If that distance is closer, then I'm SOL and it will most probably not fit.
    Thanks, bro!
    (Don't you love when you can't find this info from the manufacturer?? Why, Zoke, why???)
    Check my Site
    ...So the stock configuration provides the most bottom out and it gets cushier thereafter....
    Yes, and on the ML the stock setting of max bottom out is more than any mere mortal will need. I rode yesterday with the setting at min bottom out and never bottomed the shock. Most travel I achieved was 1 13/16" on the 4' drop in my test loop. This thing really gets progressive in the last quarter of the stroke. I think I'd have to destroy my rear wheel to hit something hard enough to hit bottom on the trail.
    The adjustment does work as I verified that I was able to achieve 2" of travel with a minimum pressure where the stock setting only allowed me 1 13/16" travel at the same minimum pressure. I am still looking for less progression and will be calling Marzy tech this week to inquire if the compression can be lightend.
    I have just switched the shock to my Quasi which has a 3:1 leverage ratio and a rocker setting that places more leverage on the shock in the last part of its travel for use with air shocks. More details on this when I get another ride done.
    Thanks, bro!
    The widest diameter of the body is a small ring right above the machined aluminum section. It is 2 1/16" in diameter and is about 3/16" wide (the remainder of the upper, larger portion of the body is 2" in diameter). This band is 2 3/16" from the body eyelet center and 5 1/2" from the shaft eyelet center. Also, the rebound knob extends 5/16" farther than the body and the air cap extends 3/16" farther than the body. Sorry for the standard measurements, I just have a tape measurer but I was quite careful and everything should be within 1/32".
    Mar 2006
    Quote Originally Posted by geolover
    D Dug
    OK...that makes sense I guess. Looks like its a true FR Shock. I personally would want a platform for climbing, but I can see not wanting it for a fully active ride.
    Dug-da-Goat
    "El Whatever"
    Thanks, bro!!
    My Float has the widest part at roughly 1 1/2" inches from center of eyelet... At 2 3/16" it should have enough clearance but I will doublecheck.
    No probs with the Standard... My caliper has an "automatic conversion device" (it measures in both IS and metric ) so, no problems there.
    Check my Site
    Dec 2005
    Thank-you titusquasi
    We need re-shimming details ...
    Dec 2005
    Thanks, bro!!
    Warp I hope you ordered one of these ... black as well
    now this looks interesting...some leaks on the 08 Roco Air.. with TST..yummy
    "El Whatever"
    Quote Originally Posted by crisillo
    Thanks, Cris!!!
    They continue to push the 55 series with TST... bummer.
    AM... no dough for bike stuff now... flying through a rough weather patch.
    Check my Site
    Thanks, Cris!!!
    no prob!
    what I wonder is what the ATA 2 towards the right in the 55 spec page means.. I know what TST 2 is.. but with ATA..maybe like RS' 2-step???..it says 120-160 adjustable, while the ATA says 125-165...
    maybe it's just a way of saying ATA + TST 2...
    gotta wait and see I guess...
    Dec 2005
    cool crisillo !~!
    The new line of roco air shocks looks the shizzle !~!
    These should perform and sell very well. I hope manufacturer's spec these.
    The 55 looks very RAD.
    I wonder what how good the rebound cartridge version is ?~? Hard to read we need better quality crisillo. When is 08 Zoke being officially released ?~?
    Dec 2005
    Thanks, Cris!!!
    Sorry to hear that Warp.
    The thing that bothers me is when you use TST on a fork the whole stroke is affected top to bottom at any speed. I leave mine open. I just can't get into the 1 click to stop brake dive thing... it just makes the fork slow.
    I don't understand what they can't make a fork with a needle in the centre of the piston to control low speed flow and have a dial on it to open or close the needle. Then simply have ports and shims near the outer part of the piston for high speed control. The shims could have an arm on them to give high speed user tuning.
    I believe the Roco TST rear shock is shimmed. I think both low and high speed go through the shim ports with an arm/spring offering manual control ?~?
    Why not shim the fork to provide speed sensitive damping... does the fork TST cartridge sort of try to do this with a series of orifices and I missed this part ?~? Has Zoke changed the 55 version of TST to make is speed sensitive ?~?
    "El Whatever"
    No worries... family's fine,work's fine, bike's fine... money is just details.
    Try with lighter oil in the TST... 5wt is working better for me. It makes transitions from low to high speeds more "seamless"... It still lacks a bit, but it's heaps better.
    I accidentally ran my fork in a position near one and two clicks (mine doesn't have the detents, I lost the spring) and descending it was feeling like it had bricks for oil in the damper. It got to soak slow things, but at fast shaft speeds it felt like a rigid fork.
    They just need to replace the thick blow-off shim and that useless heavy spring preloading it with some shims and a lighter spring... They're so close that it ain't funny. Maybe increase the flow through the orifices of the piston, but that's as far as they need to go.
    Something like that, Darren confirmed that.
    The speed sensitive part is the blow-off... but it'll never be as speed sensitive as a shim stack.
    Check my Site
    Dec 2005
    All try that.... what oil is the best... just no swelling syth ?~? I think I need to more scope in the open setting and this should do it.
    Strange thing... can you explain Warp... when I last changed my leg oils I ended up putting 50mm (not 40) in the TST side (06AM1). Since that day my TST pressure I use have been almost cut in half.... I have no idea why ?~? Everything else operates perfect. Oil tuned ETA side brilliantly a few times... man what a great feature.
    Have you thought about what just a lighter spring would do ?~? What happens if you take spring out ?~? Could the orifices in piston be bored out bigger ?~? I need to go to the revealed thread again and study study study...
    Oh well thanks Warp, you are always a great help and you are appreciated
    "El Whatever"
    Yeah, anything suspension specific... hit the moto shop and grab a qt of your favorite.
    I use Yamalube and so far so good.
    I noticed that when I missed the oil level there too... Apparently the fork is very sensitive to this oil level. I ASSUME that the bladder closes the gap between he stanchion and cartrdige, hence reducing the volume of the air chamber.
    A lighter spring there would make the blow-off to break open earlier with less force (read, less oil speed)... good if you want less high speed damping, but it could affect the rest of the travel if you go too light.
    You can't remove it or you end up with a full open damper, you'd still have the orifice n the TST adjuster shaft, but that would not be the ideal solution, I think.
    Orifices in the piston... I dunno... I'd need to take the TST compression assy apart. Maybe. But you can achieve similar (not equal, maybe not that close) with just going to lighter oil.
    Thanks for the props... but remember to take my word for what's worth... an armchair engineer. I don't make a living out of suspension like people of the likes of Darren, _MK and others.
    Check my Site
    sorry about the quality.. I just stumble upon it
    Zoke usually releases the next year stuff around late september (at least they update the website at that stage)
    Dec 2005
    sorry... I didn't go to the link until much later.
    they make us wait... I'm a little curious as to how the new 700 ATA will pan out. It must be the new trail fork option for a good majority of 5" trail bikes. 140mm travel sounds good. I wonder what the height will be.... I think the existing 130 mm travel is 505 so that might make the new one 515 unless they squash it down to 510. Wouldn't mind trying one out.
    yeah the 700 ATA looks very interesting... fairly light and Marz buttery travel
    Dec 2005
    Roco Air arrived !~!
    and a fine lookin' tough unit in real life and i dig the big shaft and will match my fork beautifully aesthetically
    My DHX C weighs in at 800 grams with 600 x 2.35 spring
    this is supposed to weigh in at 340 grams... not weighed yet but certainly feels like it
    25 clicks of rebound
    hopefully i can install and get a ride in soon....
    cool
    keep us posted
    Trophy Husband
    You're stoked!
    Dec 2005
    You're stoked!
    yeah shimmed zoke stoke
    stoked like the stoke the homers post up riding stoke i feel that stoke now and i am not riding but still stoked
    Veni Vidi Vici
    Reputation: barelylegal's Avatar
    Your a legend
    update on 08 specs...courtesy of Sicklines... now that it is readable...most of the forks are confirmed to be manufactured in Taiwan... rear shocks are made in Italy still..
    "El Whatever"
    Well... All the BS marketing aside, it looks nice!! But to be honest, that Vanilla R looks nicer and nicer.
    Thanks, Cris!
    Time to get a Roco Air R NOW!!!
    I like this one... XC600 ATA2
    Check my Site
    Thanks, Cris!
    yep... all are fine options... so many parts.. so little money ( and time )
    Trophy Husband
    TST in all the "all mountain" forks.
    No dual coil 66.
    edit: actually, there is a dual coil 66, but its RV...yuck!
    WTF?
    Marzocchi is losing its grip on one of its fanboys.
    Mar 2005
    No dual coil 66.
    WTF?
    I think the nickel plated stantchion's look cheap.
    "El Whatever"
    Same here... There was nothing wrong with the black anodized finish of current forks.
    Check my Site
    but only the "top models" have it... so probably the XC600 ATA2 that you like will come with anodized stanchions, Warp
    Dec 2005
    Zoke Stoked
    That new 66 is a beast. 38mm 1.5 and RC3. Too bad Geo's a sissie and wouldn't know what to do with one of these .... I sure as heck wouldn't.... these are bad boys !~!
    I dig the nickel toobs
    The new 700 ATA looks like a super light El ML fork. I wonder if the A2C is 510 or 515 ?~?
    Those Piggie Air Plungers shafts look huge !~!
    Perfect El Guapo shock
    "El Whatever"
    What you talkin'bout???
    Sure he knows what to do with one of those... Put it to hang on the wall aside his frame!!!
    Check my Site
    Dec 2005
    i just spit coffee on my keyboard
    "El Whatever"
    Wait a second... Weren't those nickel plated stanchions tried before by manufacturers with not very good results???
    Isn't Nickel hard to nail as coating on aluminum?
    Check my Site
    Trophy Husband
    Now I hate two people on this board. Demo, care to make it 3?
    Yea looks cheap in between white lowers and a black crown but it does have its benefits. As for no dual coil 66 well I guess some will be mad but honestly once most ride the ATA they dont go back but the bottom air valve and knobs sticking out way down there doesnt seem too promising and why the change on the XC series already the old once worked great + the corsa. Looks like ill keep my 07 AM SL1 a while since it is finally dialed in and works great no need to go and fudge things up.
  67. #67
    not sure about nickel I know Nitride was popular for a while but Marz only used it on steel (Z150) cause they didnt like it on aluminum I think but not too sure if others have used Nickel it's a first to me though.
  68. #68
    Reputation: demo_slug's Avatar
    Jan 2005
    nickel coating: it was used on a few boxxers for sure. I actually saw one about a montht ago. few years old, with heavy use... looked great. nickel has more of a brown gold tint to it. so to me it looks like nickel. which doesn't look like cheap chrome to me, i think its rad. but YMMV. it is a metal coating.... its not a aluminum oxide like ano.
    if it was good fox would use it. just kidding.
  69. #69
    Dec 2005
    Quote Originally Posted by demo_slug
    nickel coating: it was used on a few boxxers for sure. I actually saw one about a montht ago. few years old, with heavy use... looked great. nickel has more of a brown gold tint to it. so to me it looks like nickel. which doesn't look like cheap chrom to me, i think its rad. but YMMV. it is a metal coating.... its not a aluminum oxide like ano.
    I wonder if Zoke is having it done elctroless or electro-plated....
  70. #70
    "El Whatever"
    Correct me if I'm wrong but I guess electroless is the way to go with nickel. Otherwise they have to apply zinc or anything before.
    It's easy to screw it up, I think. Nickel doesn't really like to stick to Al, but it's been used on engine parts, so it's not impossible.
    Check my Site
  71. #71
    Dec 2005
    paging crisillo
    Hi crisillo
    Can you find the Zoke Stoke 08 888 info
  72. #72
    Hi crisillo
    ask and you shall receive
  73. #73
  74. #74
    sure the boxxer wasnt nitride coated? I remember the one your refering to but I thought they wer some type of nitriding not nickel.
  75. #75
    "El Whatever"
    There were some models with "Slippery Silver" that I guess it was nickel.
    The ones with TiN (Titanium Nitride) were prone to flake offs... Fact is those two coats were not the same.
    TiN and TiNC I have seen them used on ferrous materials and tool grade (cutting) steel. Makes wonderful cutting bits for CNC tooling.
    Check my Site
