    Rear shock set up X Carbon with RT3
    I just put my X carbon together, front end with a SID works excellent but I have some trouble getting the rear shock adjusted (Monarch RT3).
    To get 75-80% of shock travel I have to go down to 90 psi (I'm 72 kg/158 lbs) and that seam kind of low. At 140 psi i only get like 5% sag and very limited overall travel.
    What pressure are you running? Any ideas of if it's reasonable to run it at 90 psi or might it be defect?
    Reputation: allenpg's Avatar
    I'm about the same weight and have mine set for 105-110 PSI for about 20% sag. Try playing with the rebound. Took me a few short rides to get it dialed in.
    Did a test run with plenty of roots and rocks with the pump in the back pack. It rides really good but I still need to do some tuning to get full travel
    The Cheater
    Reputation: Veda's Avatar
    Dec 2009
    The RT3 does seem a bit stiff compared to RP23 on the initial stroke.
    Titux X Carbon 2010 race 9.93kg
    Titux X 2009 "Deore 2012" training 11.55kg
  1. Ftm Carbon rear shock settings....
    By Nilsern in forum Titus
    Last Post: 06-16-2011, 04:37 AM
  2. Carbon FTM Rear shock Fox vs RockShock
    By mw04snow in forum Titus
    Last Post: 06-07-2011, 04:10 PM
  3. rear shock on carbon Scalpel 100 ??
    By spartan23 in forum Cannondale
    Last Post: 04-04-2011, 01:29 PM
  4. Carbon SL rear shock change
    By Shiver in forum Specialized
    Last Post: 09-21-2008, 04:46 AM
  5. Stumpjumper FSR Pro Carbon rear shock PSI
    By nswartster in forum Specialized
    Last Post: 03-03-2007, 09:18 PM
