Results 1 to 7 of 7
    Feb 2007
    Racer X titanium bolt kit and replacement parts question.
    Hey guys, does anyone know if there's a 'less expensive' alternative to the Competitive Cyclist titanium bolt kit for the Racer X? Seems like $125 for 5 bolts is just so steep.
    $125 Ti bolt kit link
    Doing a quick search I found these two places:
    SRP and Pro-Bolt
    but I'm unsure of the sizes I would need.
    Is there an online retailer for to pickup a whole pivot bolt replacement kit that's not titanium? I mean all the 8 bolts that are holding the rear triangle/shock. I've had problems in the past trying to acquire parts like this for other manufacturers and would love to get some spares if they're reasonably priced.
    Another source is RaceBolts.com I've purchased from them before without issue. My last order was backordered so you might want to call ahead and check availability...
    cheers,
    scott
    parts leftover
    Reputation: schlim's Avatar
    I bought mine from Racebolts.com
    Here's the thread I looked at.
    Hueston Woods Trail Crew
    Reputation: Bikerbob.com's Avatar
    What you need
    I have both ti bolt kit and standard bolts in stock.
    Email bob@bikerbob.com
    Feb 2007
    Awesome! Thanks for the info, guess I should have done some better searching.
    Feb 2007
    Looking at the RX specs and what's available, could someone who ordered confirm this please?
    Rear Shock bolt = M8x55 SHCS x1
    Front Shock Bolt = M6x45 SHCS x1 (M6 Nylok Nut x1, M6 washer x1)
    Horst Bolts = M6x25 FHCS x2
    Rocker Bolts = M8x17 BHCS
    * 1ea.- Titanium Taper Socket Head M8X55
    * 1ea.- Titanium Taper Socket Head M6X45
    * 1ea.- Titanium Hex Flange Lock Nut M6X1.0
    * 1ea.- Titanium Washer M6 (6-4, grade 5, OD=13.55mm,thickness 0.85)
    * 2ea - Titanium Countersunk Screw M6X25
    * 4ea.- Honda Ti Rear Disc Rotor Bolt M8x17, shoulder 5mm, 90105-MV9-003
    Total: $68.90
    Edit: Added links on parts
    Edit2: On closer inspection, there are 4 rocker bolts and the countersunk ones are for the rear chainstay
    Not sure how the other "kit" is only 5 bolts when there are way more than that. Am I missing something here?
    parts leftover
    The countersunk screws from Racebolts for the horst link have too shallow of a head to adequately torque with a hex wrench. In other words, I returned them because they would have stripped out if I'd tightened them.
