Results 1 to 34 of 34
Thread: Numb wrist...
    "El Whatever"
    Reputation: Warp's Avatar
    Numb wrist...
    Hey folks!!
    This morning I took a quick spin on the bike (just literally around the block) and after a few minutes my RIGHT wrist (from base of the palm of the hand) gets numb. I can feel some reflection on the elbow too, but not really bothering on the elbow.
    WTF?? I've been running this set-up for quite a few rides. Same gloves, hbars, stem, saddle position, grips... Only change has been adding a spacer under the stem (3mm).
    My hand feels like if it would like to have a much dramatic sweep.
    The left hand is OK.
    No falls, no hits, nothing that have caused problems with the wrist.
    Would I need a wider bar??
    Remove the spacer??
    Thanks for any help!
    Warp
    Check my Site
    Death grip on the bar?
    thats right living legend
    Reputation: blackagness's Avatar
    Mar 2005
    Try relaxing your grip... firm yet relaxed. Also just to be safe get some new gloves and grips, it helps more than you'd think.
    "El Whatever"
    JC... Nope. I am loose on the bars... I even move the hands around. This is why it's confusing to me.
    BA... I'll try that, bro. Grips are coming from Montana.
    Check my Site
    Arm to hand angle?
    "El Whatever"
    Quote Originally Posted by Jerk_Chicken
    Arm to hand angle?
    Yes, maybe... Would a wider bar would help? Or a narrower one?
    I'll go step by step... grips first, then a bar...
    What it puzzles me the most it's only the right hand. I must have something wrong, either on myself or some bad posture.
    Maybe should I exercise the right arm?
    Check my Site
    Dec 2005
    9x4 bars and 680mm, if not already
    those 8x5 bars are a funky for some people
    best thing to do is get a better rear shock absorber
    you should remove the 3mm spacer to see what affect it has
    or have acute not ride enough unbalanced weak wristed syndrome
    or have been using the right wrist too often between rides leading to blindness
    Nightriding rules SuperModerator
    Reputation: crisillo's Avatar
    I don't mean to point something obvious.. but maybe try to do/undo the spacer change to compare... but as you I would doubt such a small change would do that....
    Quote Originally Posted by All Mountain
    ROTFLAO
    "El Whatever"
    Yeah, 8X5's here (RF Evolve XC Low Riser)
    I don't want to get divorced...
    I will...
    Thank you, but I'm lefty.
    Now I see why Geo hates you.
    Check my Site
    Where is my mind?
    Reputation: Cyclopod's Avatar
    Mar 2006
    How's your back? Any chance that something may have happened a little while ago (maybe even before you added the spacer (bad sleeping position, carry your son on your back, etc)? Also, why did you add the spacer?
    "'I refuse to prove that I exist,' says god, 'for proof denies faith and without faith I am nothing'"
    - Douglas Adams: "The Hitchhikers Guide to the Galaxy"
    "El Whatever"
    Quote Originally Posted by Cyclopod
    My back's never been so good... I have a shorter leg (the right one, btw) and that causes me some strain, but it's been like that since forever. I use an insole to correct that for my normal activities, but never have had it corrected for the bike. Other than that, just lack of exercise.
    I added the spacer to raise the bars just a bit when I was riding more steep stuff, but out of laziness, I haven't brought it back to what it was.
    Check my Site
    dog
    dog is offline
    sit! stay!
    Reputation: dog's Avatar
    i sometimes have the same issue when i ride some very very smooth double track...
    never happens on single track... i think it's becaue i am in the same riding position (hand-wise) for enough time to cut off the blood so i go numb... if i take my hand off the bar and ride one handed, it goes away...
    Trophy Husband
    Reputation: geolover's Avatar
    Where's Chirochris when you need him?
    Extreme stationary biker.
    Dec 2005
    Quote Originally Posted by geolover
    i can't take this anymore... too funny these days
    I could use some help with my L5-S1 rupture ....
    I wonder what happened with his wonky bike ?~?
    Where is my mind?
    Mar 2006
    Quote Originally Posted by Warp
    One very ugly word: Situps. The adjustment may have have been enough to trigger a pinched nerve in your back (thus the referred pain on you elbow and wrist). Just speculating about the source but I'd belt out a good 25 situps before bed and when you get up (maybe even before you get on the bike). I've had back issues and I will use a shim in my shoe as well but the gym has helping out quite a bit. Cycling is no friend to a bad/weak back.
    A good massage once in a while can be a big help.
    "El Whatever"
    Where's my wife when I need her???
    Thanks, man!! I'll give it a shot, but I think I'll have to lift some weights because I'm pretty out of shape.
    ROTFLMAO!!!
    Aaaaarrrrghhhhh!!!!!!!!
    Whoa, fortunately I had nothing in my mouth to spit...
    Check my Site
    Ti is addictive
    Reputation: TiEndo's Avatar
    Geez..........this thread has gotta be one of the funniest in a long time........Warp, do you think it might be computer keyboard related and bike related all tied together???????
    Or are you just bias to chokin the chicken with the rightie and not the leftie cause it can't be the fact you ride your brakes MOTO style can it???????
    Where is ChiroChris when you need him.......?
    "Can I put a Totem on a FTM?".....Originally Posted by All Mountain
    You down with entropy?
    Reputation: esilvassy's Avatar
    recent numb fingers
    Hmmm... I have been having numb fingers on my left hand on and off recently. Right now it is the pinky and ring finger. I have started down the road to adjusting things around to see if that helps. I have rotated my bars a bit and that seemed to help last night, only the tip of my pinky was a bit numb (2 nights ago I was trying differnt bar rotation and had the bars rotated too far and all my fingers went numb....)
    I am about to pull the trigger on new bars as I have 8x3 FSA bars. I am looking at the 9x5 recomendadation (probably titec hell bents) and maby the salsa moto riser which is 10x6.
    while I am at it a spare shock might show up in the order........
    "El Whatever"
    Quote Originally Posted by TiEndo
    I'm liking these bars...
    Check my Site
    Ti is addictive
    Syntace stuff is
    And maybe some ERGON grips.
    And maybe a better mouse pad as well
    yep.. Syntace rocks
    I meant to do that
    Reputation: sethm's Avatar
    The nerve that affects your pinky and ring finger runs through the Cubital Tunnel (funny bone area). You will usually feel numbness when the nerve is stretched across the elbow, usually when the arm is bent at the elbow. Some people who sleep with their arm up over their head, or work at a computer for a long time, or drive for long periods with their elbow resting on the armrest can be affected. I've been diagnosed with Cubital Tunnel Syndrome and I had been sleeping with my right arm over my head for years. The right hand is also my mouse hand. It doesn't affect me when riding, because my arm is extended. So maybe this won't apply to you, but my 2 cents nonetheless.
    Ti is addictive
    Quote Originally Posted by sethm
    That was what I was getting at with Warp..........I'm not a physician or a Chiropractor but I stayed at a Holiday Inn Express once........
    But Seriously I do believe the ERGON grips will minimize the pressure point and hold you in proper position........if you're already kinked due to work related positioning and moderating all of us nutcases, positioning (spacer) and hold(grip of death) and use(ie hours biking) will come into play with the numbness.
    Trophy Husband
    Hmmm, I wonder if there are any people out there that are both chiropractors and Ergon experts......let me think....OH YEAH! Chirochris.
    WWCCD? (What Would ChiroChris Do)
    edit: sethm...great avatar
    Reputation: mw04snow's Avatar
    Nov 2006
    Numb Hand
    Warp,
    there are a no of reasons for numbness in the hand and everyone has touched on them a bit
    1 if little finger ring finger in the hand then ulna Nerve usually compressed at the elbow
    2 if thumb index middle finger then carpal tunnel syndrome with compression median N thru the carpal tunnel - often get when riding due to pressure on palm side of the wrist
    3 However you gave history numbness ?? pain up from wrist into the elbow
    either a form of carpal tunnel or even condition like tennis elbow etc
    before going spending lots money on new gear tell me
    1 ? get symptoms any other time ?
    2 is symptoms in forearm on the volar ( palm up ) side of the forearm or dorsal ( palm down ) side + does it radiate to the inside or outside of the elbow
    Im a family physician when Im not trying to hang onto my ML
    let me know
    <Mike
    "El Whatever"
    Quote Originally Posted by mw04snow
    Warp,
    More like the whole wrist extending to the hand/fingers with time.
    Just when riding.
    <Mike
    From dorsal (palm down) towards outer elbow. Forearm per se it's fine... but definitively I can feel the wrist and elbow numb. Goes away a couple minutes off the bike.
    BIG THANK YOU, bro!!
    Check my Site
    Ride 2 Work, Work 2 Ride!
    Reputation: thebigred67's Avatar
    Mar 2005
    F.S. mouse
    I think you need one of those F.S. mouse things. The old H.T. mouse thingies can cause numbness!
    "Don't give up, Never give up!"
    Dec 2005
    Quote Originally Posted by thebigred67
    i just ordered a roco for my FS mouse !~!
    Mar 2005
    LOL!
    Nov 2006
    your prob
    a bit difficult to work it out like this
    but best guess is
    ?tennis elbow with vibration from wrist up the forearm to the outer part of the elbow
    done anything different lately ?
    should settle back down in a week or 2 ortherwise go for esigrips.
    Mike
    "El Whatever"
    Nothing different, really.
    Mike
    Will do!!
    I'll keep you guys posted... Thanks everyone for the jokes and advice!!
    Check my Site
    Veni Vidi Vici
    Reputation: barelylegal's Avatar
    Warp, 2 of my riding buddies experienced this before, they have it checked and according to the Doctor they visited, what caused it, was Vitamin B deficiency... You can try asking from AM shipping you some VEGIMITE ... it is a good source of Vitamin B...
    I know i am new here, but damn Warp, stop kidding yourself, buy some new bars and grips and be done with it. You don't have to justify it, to us that is, maybe the wife I have used all of my get out of jail quick cards on my new, hopefully , arriving motolite, in august
