Results 1 to 28 of 28
    New EG in Hong Kong
    I have been waiting for this for about 4 months.
    I nearly bought the Mk2 in early May but didn't care for the orange colour. Then I heard that MK3 was to be released at end May so I waited. When it finally debuted, I instantly liked the super "dave" raw as I had seen someone on this forum strip their EG raw and instantly liked it. But ... once I had pulled the trigger on it, I had regrets, thinking that I should have ordered it in black as I think maybe it won't look good with the forks I have in mind. But alas, like an illegitimate child, she arrived at my doorstep not caring how I felt about her. Initially, when I first sighted her, my feeling was that I had made a mistake. The raw is not smooth as some have portrayed but rather a finely brushed aluminum finish that is difficult to detect in photos. In fact, "raw" is a very accurate description. There is a degree of unfinished business about her and this "look" gives the impression that it was rushed into production.
    But in the end, the look has been growing on me. It actually gives the impression of a secret military prototype undergoing field trials and I think it's quite cool.
    Without further adieu:
    Attached Thumbnails Attached Thumbnails New EG in Hong Kong-img_3464_5_1.jpg
    More photos:
    First impressions:
    Build quality: generally very good. It certainly looks that way. The proof will be in the ease of build. I am assured by Brant that the bottom bracket shell does not require chasing nor does the headtube require facing.
    The frame from all angles appears extremely robust. The underside of the chainstay looks like it belongs on a 125 motocross bike - more photos later.
    The Cane Creek DB appears absolutely enormous. I was quite "shocked" by the size of it. It doesn't just appear to belong on a 125, I think maybe they have taken it off one! Actually the frame cannot handle anything bigger. There is maybe 1mm of clearance between the shock body and the seat stay/downtube linkage.
    Speaking of build, this is my first ever full build and I welcome your input. Coming is a 2012 Bos Deville fork with a 1.125 steer tube and a 1 deg slackset from On One. I have an XT 3 ring crankset that I want to take from my other bike and at this point my intention is towards replacing the 3rd ring with a bash guard. The chain tensioner will be a bionicon as it is light, cheap and i understand that it is effective.
    More later ...
    moar alike..
    Reputation: Deerhill's Avatar
    Dec 2009
    Good job! large pics! thank you may I have another
    Quote Originally Posted by rottenronny View Post
    more photos:
    -drool
    How deep is the shoulder in the head tube for the headset? Also, close-up of the cc shock and the down tube clearence. Thanks.
    Reputation: George Gr's Avatar
    Nice!
    Waiting for more pictures and full specs.
    "Do not go where the path may lead. Go instead where there is no path and leave a trail" Ralph Waldo Emerson
    Quote Originally Posted by doralswheels View Post
    Bottom cup depth 0.800 inches = 20.3mm
    Top cup depth 0.437 inches = 11.1 mm
    Clearance from centre of forward shock pivot to downtube 2.725 inches = 69.2 mm
    Closest point of CCDB to downtube 0.930 inches = 23.6 mm
    I will try to get the photo you want later. Card reader problems atm.
    Attached Thumbnails Attached Thumbnails New EG in Hong Kong-img_3449-copy_2_1.jpg
    Fork: Bos Deville 160mm
    Wheels: Hope Hoops Pro2 Evo MTB (Black Mavic 721)
    Crank Brothers Split Skewers
    Pedals: Shimano M530 MTB SPD Trail Pedals - Black
    Hopetech EVO 4 brakes with 203mm disks front and rear.
    Would anyone like to suggest a crankset? I want to run Shimano. I guess a 2 ring with a bash ring is the answer? Not sure if that impacts the crank decision (my first build and I am learning). I do a fair amount of uphill. Trying to keep costs under control so am interested in deals. Also .. shifters, front and rear mech?
    125 swing arm
    Attached Thumbnails Attached Thumbnails New EG in Hong Kong-img_3450_2_1.jpg
    Reverb
    Can anyone provide some guidance for a Reverb seatpost for the Large EG? I am 6'-0" have a 34 inch inseam. I understand the choices are 380mm or 420mm post with 100 or 125 range of motion. Thanks,
    moar alike..
    Dec 2009
    125 swing arm
    Reputation: anvil_den's Avatar
    Nov 2007
    Not a reverb fan but if its clearance you are concerned with..generally 125mm adjustable post-- requires ~8" +/-0.5" from top of saddle to max insertion point. The longer version shouldnt be a problem for you.
    Off the back...
    Reputation: pinkrobe's Avatar
    I have an SLX triple with a $20 FSA plastic bashguard. Works great, and I can sell the big ring or use it as a wind chime.
    @pinkrobeyyc
    #pinkrobeyyc
    Quote Originally Posted by anvil_den View Post
    not a reverb fan but if its clearance you are concerned with..generally 125mm adjustable post-- requires ~8" +/-0.5" from top of saddle to max insertion point. The longer version shouldnt be a problem for you.
    I'm actually not a fan either as I know they aren't the most reliable tools in the shed but i wanted a dropper post and this one I can get new for USD $200 delivered so I thought I would take a punt. I waffle about buying it and sometimes think that I should just buy a clamp like this:
    Seat QR - Chromag Bikes
    I may go down the man route yet. Thanks for your helpful advice.
    Quote Originally Posted by DeerhillJ View Post
    Precisely.
    Camera lies in 2nd photo but the reading is 15/16ths = 23.8mm. Hope this helps.
    Attached Thumbnails Attached Thumbnails New EG in Hong Kong-img_3468_1_1.jpg
    -drool
    Paws off or I'll scratch yer eyes out.
    Attached Thumbnails Attached Thumbnails New EG in Hong Kong-img_3431_3_1.jpg
    Frame Oopsies
    OK. Now for a couple of criticisms:
    1. The Titus badge on my frame is cockeyed. Not a deal breaker in my mind - just sloppy factory assembly. After all, it is the focal point for the frame for anyone who is interested in the marque and it reflects negatively on Titus QC. The factory has gone to lengths to protect the badge with extra plastic cover. It should be on straight - nuf said. Photo shows seat tube(out of focus) aligned behind head tube.
    Attached Thumbnails Attached Thumbnails New EG in Hong Kong-img_3459_3_1.jpg
    wow, really sexy look and feel to that super raw. man i'm jealous...
    ah, crooked badge can be annoying but can easily remove by heat it lightly and and re glue ...
    EG cable guide
    The rearmost single cable support bracket on the RHS of the front triangle is mounted about 0.5 inch behind and in-line with the RH forward shock mounting bracket rendering a cable mounting in this position seemingly useless as the proximity of the shock mount would kink the cable. Likewise the front cable support is also mounted in-line but should be workable as it is about 2 inches from the same said bracket. It's position could be much improved by mounting it further inboard and/or rearward thereby providing a straight run for the cable. Brant confirms this is not a welder's error but the correct specified position. I have seen photos of this mount being used but i think that it is a design that could be easily improved to allow a straight run for the cable.
    Attached Thumbnails Attached Thumbnails New EG in Hong Kong-img_3458_1_1.jpg
    Quote Originally Posted by Broadica View Post
    Thanks for that. I may try it but frankly there is riding to be done and once I'm in the saddle, I can't see it. Maybe a rainy day project.
    moar alike..
    Dec 2009
    Precisely.
    Nice and solid, hope it doesn't get lightened up in the future
    How long between head tube and seat tube in the Mk3?
    Large frame - center to center 58.8 cm via tape measure.
    Or 54.5cm outside of head tube to outside of seat tube according to your red line in diagram.
    Some more photos.
    I don't know what the material is in the linkage (1st photo). It's certainly different from the rest of the frame. Magnesium? It has some limited CNC marking in the cavities, otherwise it is smooth.
    Attached Thumbnails Attached Thumbnails New EG in Hong Kong-img_3422_1_1.jpg
    -drool
    Where did the cute puppy go?
    moar alike..
    Dec 2009
    Makes short appearances.. when a thread delivers : )
    Pretty sure rocker is aluminum? tt grew 13mm, very nice
    That an old Giant AC?
    moar alike..
    Dec 2009
    build up that large yet?
    LOLS! What a great analogy!! T2 in progress! This is going to take a little longer than most of you would put up with (living in Hong Kong is a challenge). Most of my parts are coming from Europe/UK as bike shops here are a little pricy and I want to keep costs under control. 1 deg Works slackset arrived from UK yesterday. Bos Deville forks are being packed with Bionicon chain guide and Reverb from Bikeinsel in Austria. Most of the other parts I will strip from my current ride and utilize those until I find some online deep discounts or closeouts on some other parts.
    Best riding season is in Nov through Feb here. Currently temperatures 35 with RH around 70 to 80 pc which can be quite limiting so I can afford to be patient with the build. Will post again with photos when more parts arrive.
    In the meantime, I am getting a lot of good information from this forum regarding CCDBair shock setup (not optimistic but will give it a go) and chain guide selection and setup so thanks to all for the contributions to this forum.
