Results 1 to 5 of 5
    Reputation: millsm's Avatar
    Mar 2006
    Need help with main pivot bolt stripped out
    So, I have a 2007 Aluminum Motolite, & I bought one of the colored aluminum kits (derailleur hangar, rocker bolts, seatclamp, & main pivot bolt) from Titus a few years back. I'm getting a little bit of side-to-side play in the main pivot (I can grab the chainstays and pull it back & forth a little bit with a clunking noise). I went to pull the bolt, but it's seized & I rounded out the 8mm allen hole, as the bolt's aluminum (bad idea). Question is do I just leave it and live with it (have for a few months now), or do you all think a shop can drill it out? The play's not getting worse, but is a little unnerving at times, and i'd like to replace the bearings sometime in the future, along with the original steel bolt which I still have. Thoughts?
    Hey, I didn't see that rock there."
    likes to rides bikes
    Reputation: VR6ix's Avatar
    Quote Originally Posted by millsm View Post
    Thoughts?
    If you're intent on trying to remove the bolt, find a Torx bit big enough to hammer into the rounded-out Allen head of the bolt, you want the 6 lobes on the Torx to actually cut into the Allen head where the 6 corners used to be, so make sure the Torx bit is big enough before swinging a hammer on it! Use a cheater bar to get some torque on it and see if it will loosen off. You can't really screw it up any more by trying that...
    I had to do this once or twice on aluminium and steel bolts and it's worked for me, YMMV
    also known as Plaid Shirt Guy...
    Mar 2006
    Thanks, but I wonder if that would work. When I initially tried to pull the bolt with the allen wrench, it fit in there perfect (no play), but still managed to round out. I guess it's worth a try - thanks for the tip!
    There might be just too much LocTite on the threads. Sounds like an up-hill battle for sure, good luck!
    Mar 2006
    No Loctite - I just greased the threads real good before I installed it.
  1. GT RTS main pivot
    By zonoskar in forum GT
    Last Post: 04-18-2013, 01:43 AM
  2. Element 950 main pivot bolt
    By Learux in forum Rocky Mountain
    Last Post: 03-24-2013, 09:26 AM
  3. Intense M1 Main Pivot Bolt Stuck ?
    By heavyp in forum Intense
    Last Post: 05-28-2012, 02:29 PM
  4. Replies: 10
    Last Post: 10-13-2011, 12:30 PM
  5. Need main pivot bolt!!!!!
    By Coopie in forum Diamondback
    Last Post: 09-14-2011, 12:27 PM
