Old 01-17-2012   #1
jjkitt's Avatar
Rep: jjkitt is on a distinguished road
user gallery
My FTM build project
Thought I would share some pictures of my build project.
I've always wanted a Titus but never could get my hands on one. With the transfer of the brand to On-One and a new purchase point I bought a medium FTM frame in November 2011 as a learning build project. The guys at Titus couldn't have been more helpful. This is my fifth full suspension bike, so I'm using legacy components and last years sales items I find on the web.
Just installed my headset, fork, and stem last weekend. Next weekend I plan on installing my bottom bracket and crank.
Thought I would share some pictures and get your thoughts. I was thinking of using colored shifting cable housing. Maybe white or blue....any thoughts?
More pictures to follow next week.
Cheers,
jjkitt is offline   Reply With Quote
Old 01-20-2012   #2
jjkitt's Avatar
user gallery
Update to the build...slow but steady. Plan on putting on different tires...maybe Maxxis or Continental Trail Kings.
Cheers,
Old 01-20-2012   #3
jjkitt's Avatar
user gallery
Sorry, the pictures.
Cheers,
Old 01-22-2012   #4
searcher
kovi's Avatar
Rep: kovi is on a distinguished road
user gallery
Nice one! That fork is a good match to your frame.
__________________
Kovi
kovi is offline   Reply With Quote
Old 01-22-2012   #5
jjkitt's Avatar
user gallery
Update to build, installed my bottom bracket, crank, and rear derailleur this weekend. Overhauled a 2009 X-9 derailleur I had on an old bike. Got a great deal in the XX 2X10 crank...cheaper than an X-9, and my weakness for Chris King caused me to get his stainless steal bottom bracket. I have a front mec X-9 on order as well as some Gore shifting cables and a Loader Precision Inc seat post.
Hope all is well with everyone.
Cheers,
Old 01-22-2012   #6
Vespasianus's Avatar
Rep: Vespasianus is a name known to allVespasianus is a name known to allVespasianus is a name known to allVespasianus is a name known to allVespasianus is a name known to allVespasianus is a name known to all
user gallery
Dude, that looks really nice. Great job.
Vespasianus is online now   Reply With Quote
Old 01-23-2012   #7
Bike Addiction
00sable's Avatar
Rep: 00sable is on a distinguished road
user gallery
Nice build. This has been asked before on another thread but do you know the frame weight?Stuck in between EG and FTM.
__________________
Disclaimer: Always get a second opinion cause I'm just guessing
00sable is offline   Reply With Quote
Old 01-23-2012   #8
user gallery
This is coming out of my arse but I think the FTM is closer to 6lbs and the EG is closer to 7.
Old 01-23-2012   #9
jjkitt's Avatar
user gallery
To all,
Thanks for the comments...its been fun building my FTM...learning a lot.
00sable,
I did weigh the frame with shock when I received it in Nov11. I believe it was around 5.5lbs-ish...sorry didn't take any pictures. I will weigh, in its current state, today and take a picture and post. Sorry I couldn't be more helpful...guess my memory if the sign of my age!
Cheers,
Old 01-23-2012   #10
jjkitt's Avatar
user gallery
All,
Incomplete build weighs 24lbs, 4oz.
Still require:
Loaded seat post: 280gr
Sram pc1091r chain: 255gr
saddle: 224gr
X-9 front mec: 133gr
= 892gr/1.9-2.0lbs remaining.
So looking at a sub 27lb 5.5" trail bike!
Cheers,
Old 01-23-2012   #11
Bike Addiction
00sable's Avatar
user gallery
Thanks JJ and Vesp. I thought the other thread read 5.8 lbs for Med FTM and 7.25 lbs for large EG. Going back to check Craigstr's weight on his EG thread to be sure. He got a large 2011
__________________
Old 01-23-2012   #12
jjkitt's Avatar
user gallery
No worries 00, sorry I couldn't be more helpful. I've been following Craigstr's posts...since he is a Titus brand ambassador he might be able to give you the exact weight specs for both if you PM him.
Cheers,
Old 01-27-2012   #13
Rep: krtwinger is on a distinguished road
user gallery
Great looking build
krtwinger is offline   Reply With Quote
Old 01-27-2012   #14
jjkitt's Avatar
user gallery
Winger thanks for the comments.
On a separate note...has anyone have any experience with "SHOCK EYE
NEEDLE BEARING CONVERSION KITS"? Has anyone used them and do they offer any real benefit? For your reference go to this link...http://http://www.enduroforkseals.com/id275.html
Appreciate anyone's help/advice.
Lastly, final parts are coming in...should have the FTM completed by mid next week. Will post.
Cheers,
Old 01-27-2012   #15
jjkitt's Avatar
user gallery
Sorry...didn't correctly post link:
RWC SHOCK EYE NEEDLE BEARING KITShttp://www.enduroforkseals.com/id275.html[/URL]
Cheers,
Old 01-28-2012   #16
Bike Addiction
00sable's Avatar
user gallery
I read a thread a while back that discussed those bearings for shocks. What I got out of it was that the shock didn't move enough when mounted horizontal, like on your ftm, to benefit as opposed to the vertical shock position, like some other suspensions, where there is more circular motion on the top eyelet of a vertical shock and seemed to have smoother travel with the needle bearings. Just some peoples opinions though. No science behind it or testing that I remember reading about. Try searching RWC in here. It might pop up but its been a couple of years since I saw that.
__________________
Old 02-01-2012   #17
Et tu Tite?'s Avatar
Rep: Et tu Tite? is on a distinguished road
user gallery
Cheers,
I'm not sure I'd bother with the needle bearing version. I'm sure it'll move smoother, but will you really notice it? And adding more bearings, i.e. more moving parts just worsens any mean time to failure calculations as I see it.
There was a very lengthy thread - 09 FTM Broken Swing link Shock Mount Bolt! - on this forum regarding the replacement of the shock eye reducers with something more substantial. Some very useful information in there if you're prepared to wade through the willy swinging contest!
I have just replaced my shock eye reducers (on the swing link side only) with these: Bicycle Suspension - TF Tuned Shox Heavy-Duty Mount Kit, 12.7mm, M8x40 for GBP12.50. It has a steel shaft that goes through the shock bushing (which is polymer, so you replace the DU one) and "sleeves" the bolt. Cheap at the price and unlikely to fail any time before I hang the frame on the wall for sentimentality..
Et tu Tite? is offline   Reply With Quote
Old 02-01-2012   #18
craigstr's Avatar
Rep: craigstr is a jewel in the roughcraigstr is a jewel in the roughcraigstr is a jewel in the roughcraigstr is a jewel in the rough
user gallery
Sorry, didnt see this.
My large 2011 frame was 7.14 lbs with no cups or seat collar. After I stripped the paint it was 6.96.
__________________
Titus Brand Ambassador
Test Rider - DSP Racing
Dont be bashful, sign your neg reps!
craigstr is offline   Reply With Quote
Old 02-01-2012   #19
jjkitt's Avatar
user gallery
Hey, thanks to all with the comments and information. I think I'll pass on the needle bearings!
As for the build...looking to be finished by Sunday with a trail test to follow. Hopefully post the final pictures by next week.
Again, thanks to all!
Cheers,
Old 02-03-2012   #20
Bike Addiction
00sable's Avatar
user gallery
Thanks Craig. The raw looks great. If there is paint left on the frame I could'nt find it in your pics.
__________________
Old 02-10-2012   #21
jjkitt's Avatar
user gallery
All,
Finally finished my build:
frame: 2011 Titus FTM aluminum (med)
headset: Chris King Inset 3
stem: Thompson X4, 70mm, 0 rise
bars: Race Face Atlas (green)
grips: ODI lock on
post: Loaded Precision Inc
saddle: Chumba Zulu
fork: 2011 Fox Fit 140 tapered with through axle
shock: Rock Shock Monarch RT3
drive train:
X9 medium cage rear derailleur
X9 2X10 front derailleur
XX 2X10 crank (39, 26 T) 170mm
Sram PG 1091R chain
Sram PG 1070 cassette
Chris King bottom bracket
peddles: Crank Brothers
brakes: Avid Juicy 7, 180mm front, 160mm aft
wheels: Stan's Arch with Chris King hubs
shifting cables: Gore
tires: Continental Trail King 2.2 (with Stan's No Tubes)
Total weight: 27lbs 2 ounces
Going to upgrade the bolts with blue anodized titanium over the next several weeks.
Going to try a test ride tomorrow if the weather holds!
Cheers,
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Thread Thread Starter Forum Replies Last Post
Fatback build project DirtDad Fat Bikes 37 2 Days Ago 01:01 PM
My 2012 Karate Monkey Build - rigid, SS thomasbien Surly 27 04-16-2012 02:44 AM
Aluminum Fatback Build Video Dave in Driggs Fat Bikes 8 01-17-2012 11:08 PM
MTB Build Kits pricey? NoBalance Where are the Best Deals? 5 01-14-2012 09:53 AM
Hot Deals
Latest Mountain Bike Articles
Latest Lights Shootout Articles
Press and News Articles
Interbike - Virtual Trade Show Booths
Powered by vBulletin® Version 3.8.7
Copyright ©2000 - 2012, vBulletin Solutions, Inc.
Search Engine Friendly URLs by vBSEO 3.6.0
