Results 1 to 2 of 2
    Motolite Shock Mount Hardware
    Hi All
    My motolite has just started to develop a bit of play in the lower DU bush. Having looked at it it has scored the hardware so I'm going to replace the lot. I've seen various different companies kits which all look great leaning towards the RWC one and having it sent to the UK. However when I have measured the kit I have already the size contracts what these suppliers have, to my eye (with a tape measure) it looks like 39mm.
    Does anyone know the actual size required?
    Ta
    Matt
    Ultimated Outsider
    Reputation: sundowner's Avatar
    The size that RWC recomends fit my ML. You need to look for what year your frame was built.
    If I disagree with you, it's because you are wrong.
