Results 1 to 2 of 2
    Reputation: ironlegsracer's Avatar
    Moto Lite shock pressures
    I wiegh right at 190-200lbs. The bike is an 07' with a fox float 32RL with 130mm up front and a fox float rp23. What's a good baseline pressure?
    Reputation: Vespasianus's Avatar
    With the float front, I can't say. But with the RP23, aim for ~75% of body weight. I weigh the same as you and when I had the stock RP23 with the low volume sleeve I used 150lbs of air.
    This would give about 25% sag, which is what you should aim for.
