Results 1 to 31 of 31
Thread: Moto-Flare
    FM
    FM is offline
    Reputation: FM's Avatar
    Apr 2003
    Moto-Flare
    got some new flare for the motolite! (sorry, saw office space recently)
    new stuff:
    truvativ stylo crankset & sram chain (no more square tapers!)
    e13 bashguard
    Also- rebuilt my rear hub, drilled out my cables stops for full length housing, changed the fork oil, and generally gave the bike a once over... I think it's ready for 2007!
    Dec 2005
    !~! Flash !~!
    thats right living legend
    Reputation: blackagness's Avatar
    Mar 2005
    Daaaaaaamn!!!
    That looks the shizzle! Red baby red! I've been doing the whole add on overhaul thing myself lately. Think I might stop by the blood bank to help pay for it.
    Should we start a Titus board minimum for pieces of flare one is requiered to have on thier bike?
    Dec 2005
    Paging Coolio
    FM
    I put 175 / 50 ml in my fork. How much did you use ?~?
    Can you give me the good oil on Sturdy's Traction vs Speed direction ?~? I mounted my UST Sturdy's on traction and dig it so far. Curious as to why they bothered dual marking.
    UST + Stans = Nirvana
    "El Whatever"
    Reputation: Warp's Avatar
    Quote Originally Posted by All Mountain
    FM
    Sounds about good for your weight.
    Go out, ride it... If you use all the travel with no harsh bottom out on the sickest things you have around, then you're golden.
    If you're not using full travel, take out a few ml's out of the ETA side with a syringe... until you get it spot on.
    Just beware!! Too little oil on the ETA side and the ETA will not lockdown!
    Check my Site
    "El Whatever"
    FM... the only thing that comes to my mind when I see your bike is "LUST"
    Dang, it's gorgeous!
    Check my Site
    FM
    FM is offline
    Apr 2003
    FM
    yeah I went exactly per Warps reccomendations. 40cc in the TST leg, the other leg I filled until the oil was 50mm below the threads in the crown (no spring, rod pushed fully into fork). I haven't ridden it off road since the oil change but it feels great in my yard.
    PS, Warp- I have the photos for you, but have temporarily misplaced the cable I need to DL them off my older digi cam. Sorry- I'll get them to you soon enough....
    Nightriding rules SuperModerator
    Reputation: crisillo's Avatar
    Those cranks and bash look great FM!
    Sweet red accents!!
    Dec 2005
    Quote Originally Posted by FM
    Marzocchi was consulted and 175/50 was the shot after discussions. They were extremely helpful and knowledgeable . I was just wondering what volumes you used...
    Quote Originally Posted by Warp
    It takes quite a bit more effort to use the travel now and reacts way better in the rough at speed. TST air pressures are half of what I used before. It's feels very different than stock but I think it's very close to spot on for my needs, and it has really changed the character of the fork for me (for the better). Just a simple bit of oil tuning !~!
    "El Whatever"
    Yeah... I guess I stated before. This fork is specially sensitive to tuning. It's kinda hard to find the sweet spot, but once you get there... man, this thing is sweet!!
    Never think you got the most out of your Zoke until you make the first oil change. Never. These beasts get better after break-in and fresh oil.
    Check my Site
    Dec 2005
    Yeah, one of the doods I ride with said he just changed his Z1 oil and could not believe how much better it was.
    FM
    FM is offline
    Apr 2003
    I never pay any attention to the direction on the tire....
    when you are looking down, I always have the chevron/arrow patters pointing forwards on the front tire. This creates a forward-facing scoop when you are braking, better braking performance. On the rear if you are looking down, I have the chevron/arrow patters pointing backwards. This creates a rearward-facing scoop when you are pedaling, better climbing performance.
    I go with that set-up pretty much regardless of brand... not sure if it really makes a noticable difference...
    Dec 2005
    Wink FM made me do it !~!
    Red is contagious.... 36t E13 with 22/32 rings (saving for a future 34t Blackspire)
    AM's Moto-Flare :
    (excuse the hose mess)
    ಠ_ಠ
    Reputation: dulyebr's Avatar
    FM
    AM,
    From what I understand, you should typically use the traction direction on the rear, and speed for the front.
    Mar 2005
    Aaahhhh!!!
    AM's Moto-Flare :
    I want one!!!!
    "Its All Good"
    Reputation: Whafe's Avatar
    Looking good FM, that gives it a dash of colour, which is still the SH!T without looking busy................Now get busy on it...............
    Reputation: Dominator13's Avatar
    Go with the Red CK Hubs! It's the right thing to do!
    FM
    FM is offline
    Apr 2003
    Quote Originally Posted by Dominator13
    I already have black ones
    Dec 2005
    Quote Originally Posted by dulyebr
    AM,
    I mounted them both traction. I saw traction arrows and by brain followed those arrows ...
    From what FM and you say I need to turn my front around to speed direction . Then there is no plausible way the traction direction would be beneficial in the front.... but if the front brake bite gets any better speed than it already is with traction .
    Quote Originally Posted by blackagness
    I want one!!!!
    black, clear, orange, red, white ... pick your colour !~!
    I always run medium cage D's. I kept the same chain length when I swapped XT for X9. The photo in my post below I didn't shorted the chain yet for the 2 ring setup, and took off 2 links after the photo. I could take another link off, but debating on whether to get the 34t now or wait for new chain and rear cluster. You don't even have to take the crank arms off to put one in... as the big ring slides off the crank arm. I did have to undo the small ring as the sleeve nut clashed with a tooth on the small ring. The shorter chain makes a world of difference and is why I always used medium cages. Now it's only better. With your speed you may want to consider at 24/36 front combo. I can use all 9 cogs in the 32 ring and use the biggest five on the 22 ring (almost the sixth but drags a bit on the bottom plate of the front D).
    FM -- drilled out stops -- i need pics
    FM,
    give me some close ups of you your drilled out cable stops. I have been wanting to do this as well. Currently my bike looks similar to how All Mtn has his rear derailleur cable mounted.
    Did you just drill out the stops on the seatstay? or did you also do the ones under the top tube? Currently I just zip tie the rear derailleur cable to the rear brake cable under the top tube.
    more pic please. What size bit did you use?
    thanks
    ed
    locked - time out
    Reputation: the_colorado_kid's Avatar
    Quote Originally Posted by eman2
    FM,
    thanks
    ed
    Yeah man, give up the goods. I'd like to see those pix as well!
    FM
    FM is offline
    Apr 2003
    Quote Originally Posted by the_colorado_kid
    hey guys- I'll try and take some pics but really there's nothing to it. I started out with a conical dremel bit but ended up using a 1/8" or so drill bit on the dremel, and just hogging out the closed side of the cable stops. I did the seastay only, and am using zip-ties to run all the cables underneath the top-tube. (I have my gravity dropper cable too). two tips:
    use some extra housing to test the fit as you go, and keep it tight to prevent the housing from moving around.
    wrap everything up in electrical tape to avoid paint damage, you can remove it when you are done.
    the new cranks and overhauled fork&hub were great tonight- too bad about the front wheel.
    Dec 2005
    ... too bad about the front wheel.
    does it spin kinda funny now... if at all
    Dec 2005
    I forgot this photo with the front wheel on. Too lazy to cut brake lines...
    Mar 2005
    Looks good Mang!!!
    well, I did it.
    well, I did it! Drilled out the stops for the rear derailleur. Just the 2 on the seatstay. Its pretty tight in there but shifts just fine. That sure cleans up the seatstay -- before I had a few jagwire cable guides and a lot of zip ties. The housing I am using is 4mm so it looks like I could still run housing with ferrules if I ever wanted to go back. I still might put a "whafe" bling cable guide at both of the stops -- the housing is only trapped on a small bearing surface -- with suspension movement I am worried it might wear out the vinyl housing coating quickly.
    Mar 2005
    Fm!!!
    I don't know if this has ever come up before, but looking at your FR derailure cable makes me wonder if your getting full travel???
    I have the same FD "I think" and I started noticing that I seemed to be getting less travel after installing it. So I let the air out of the shock, and compressed it to reveal that the steat tube brace was hitting the front D cable. So I zip tied it closer against "but not touching of course" the seat tub. Anyway it seemed to work, but I'm sure if it were a prob you would have solved/mentioned it so...
    BTW... Eman2! def go with the Whafe bling!
    Pics of full housing to rear derailleur
    for your visua enjoyment
    A few whafe "bling cable" guides in there -- I feel the one at the upper stop is need because of the suspension movement, not so sure on the one at the lower stop. It sure does clean it up.
    Reputation: wddamf's Avatar
    Guys,
    Thanks for the bash ring idea - I honestly never thought of it since we're all XC down here (New Orleans). But, we have plenty of logs on our trails and I occasionally get one wrong, dig the big ring in, and get LAUNCHED! Since slapping on a bash ring, I just pound over stuff with abandon!! It's great!!
    "El Whatever"
    Quote Originally Posted by wddamf
    Guys,
    IMHO, you don't need to go big or have specially gnarly trails to have a bashring. I almost feel ashamed of using only like 12-14 gears off my 27sp one... but that's what it is...
    I'll wear my rings and then go for a bash plus 2 rings. More used gears and more ground clearance.
    I'm getting more and more convinced that 8sp and 2 rings is all you need for MTB.
    Are you in NOLA? You may get hooked up with my buddy Tigerdog... look for a black XL Turner Burner with Louise BAT Carbon discs on it...
    Check my Site
    ಠ_ಠ
    38 teeth of flare
    I just replaced my big ring with a BlackSpire 38t DH ring. You get better clearance and still have a triple. I just threw it on my bike last night.
