Results 1 to 2 of 2
    Reputation: Salty 1's Avatar
    Mar 2006
    MLII Ti vs MLII AL 3 vs 4 main pivot bearings..why?
    Hi all
    Can someone tell me why the Ti ML has 3 main pivot bearings and the MLII AL has 4 ??????
    Good question. I've asked the same thing before and never got an answer. I know that the Ti ML bearings are larger in diameter (outer) and 2 mm wider. So the stack of bearings in the Ti ML is actually wider than that of the AL. The Ti has two bearings side by side on the drive side and only on the non-drive side.
    cheers,
    simp
