    Reputation: titusquasi's Avatar
    ML Reducer sizes?
    Who knows the exact spec on the ML shock reducers? Front is M6 x ? and rear is M8 x ?. Thanks a bunch for any assistance.
    Reputation: Snoops's Avatar
    Mar 2006
    Rear Shock bolt = M8x55 SHCS x1
    Front Shock Bolt = M6x45 SHCS x1 (M6 Nylok Nut x1, M6 washer x1)
    Horst Bolts = M6x25 FHCS x2
    Rocker Bolts = M8x17 BHCS
    Fear and Desire
    Mar 2006
    The content may be as questionable as the previous post where I obviously had my head up. Anyway, this is what I was told:
    39mm and 30mm are the reducer sizes. this is the entire width of each end including the shock. the bottom reducers are 13mm wide per side and the upper are 8mm per side.
    Fear and Desire
    "El Whatever"
    Reputation: Warp's Avatar
    Quote Originally Posted by Snoops
    Same as SB????
    Check my Site
