What if.................
Titus took an El Guapo and redesigned slightly stronger, with an 8.75x2.75 rear shock by moving the upper mount further up, this would also require the seat tube be at much slacker angle to allow for the extra wheel travel, and would still keep the leverage ratio nice and low. Keep all the other angles the same, bb heighth, chainstay length, the only other changes would be to allow for a 180mm fork, a 67 degree head angle, and shorter seat tubes across the board ( nearly 21'' on a L frame, drop it down to 19.5"). If the weight of the bike could be kept to around 9.5 lbs it'd be the sweetest FR bike ever, I wonder if Titus will custom make me one Oh, and you could have a name that would reinvigorate a classic.........THE SuMo G!
