Results 1 to 7 of 7
    Reputation: TNT-Spot's Avatar
    Help : Bottom Bracket Lenght
    Hi Guys, I'm planning to get the New Race Face NEXT Carbon Cranks for my Moto-Lite Project. I saw that there is a 68mm & 73mm Bottom Bracket lenght in the specs.
    What is that? What should I get for the Moto-Lite, 68 or 73mm?
    Need help on this. Also, kindly enlighten on what is the meaning of that dimensions.
    Thanks in Advance.
    Cheers!!!
    ಠ_ಠ
    Reputation: dulyebr's Avatar
    73mm
    means one spacer drive-side.
    What's the rest of your build?
    Look on the Race Face site in Tech> installation>cranks for a good explanation. As indicated abve 73mm with one spacer
    Thanks for the info.
    @ dulyebr! Thanks also. The rest of the build will be SRAM X.0 Triggers / Rear Der.
    C.King Hubs on DT 4.2D, 2009 TALAS RLC, Thomson X4 Stem , Thomson MasterPiece Seatpost, WTB Pure V Team Saddle, Magura Marta SL Brakes, C. King Headset . C. King Bottom Bracket, Scwalbe Nobby Nics, TIME ATAC XS Carbon Pedals, Race Face NEXT Handlebar.
    I am also thinking if I can use the X-Gen Front Deraileur on the ML. Maybe you can help me with this. Is is possible? I heard that ML require a Low-Band Front Deraileur.
    Thanks again!
    ಠ_ಠ
    Quote Originally Posted by TNT-Spot
    Thanks again!
    Sounds incredible.
    I'd go with Shimano. I found that going XTR over XT made a meaningful difference in shifting performance.
    Are you replacing the Turner?
    Quote Originally Posted by dulyebr
    Sounds incredible.
    Thanks! Well, I'm thinking of Running Shimano free on the drivetrain. Do you think I can use a SRAM X-Gen Front Deraileur?
    I'm keeping my Spot.
    ಠ_ಠ
    I believe one the guys, rzozaya1969, ran a sram fd. on his MotoLite. Shoot him a PM. Look forward to reading your impressions and seeing some Titus pr0n.
