Results 1 to 3 of 3
    Sep 2004
    HCR with fox fork - rebound cap interference with down-tube
    Any HCR owners with this problem? The frame is equipped with a CK headset which may be contributing to the issue. I looked at the CK 5mm baseplate, but not really wanting to screw up the handling by increasing height. Looks like I might be able to grind off the ridges on the knob to gain clearance. It would look crappy, but I would preserve my handling.
    Guess I could change forks, but the fox is a pretty good match.
    Sep 2004
    I got a closer look today and grinding the rebound adjuster cap down is not an option as the screw itself is still going to hit. Loving the bike though. I have had two 80mm racer X's and a 100mm hammerhead previously and this HCR SS is a great ride. Guess I will just go with a different suspension fork or maybe go rigid instead and drop a bit more weight.
    Sep 2004
    Ended up keeping the fox fork and just using the thicker Chris king crown race. Worked perfectly with no more adjuster clearance issues and the bike still handles great.
  1. Fork rebound adjustment?
    By rickcin in forum Shocks and Suspension
    Last Post: 02-16-2013, 10:11 AM
  2. Fork Rebound Problem, Need Help!?
    By OK_MTBer in forum Shocks and Suspension
    Last Post: 02-02-2012, 09:02 AM
  3. Fox Float RL Fork - Rebound Not Functioning
    By ncfisherman in forum Shocks and Suspension
    Last Post: 12-08-2011, 11:52 AM
  4. Headset/fork interference
    By Pisgah2000 in forum Bike and Frame discussion
    Last Post: 11-15-2011, 11:08 PM
  5. No dampening on last ~1" of fork rebound
    By snmhanson in forum Shocks and Suspension
    Last Post: 07-19-2011, 10:01 AM
