Results 1 to 10 of 10
    Ghost shifting sugestions?
    Howdy all
    Ive got a 2009 small motolite frame that i recently built up. bike rides great, as im sure many of you know.
    I did get a good bit of ghost shifting in the rear derailleur on the one and only ride so far. I am currently running the housing inside the rocker link and have tried above and below the torsion bar.
    I have the derailleur adjusted to work better in the 'saged' position, but this seems a little ridiculous on such a high dollar bike. My understanding is that this is a bigger problem on the smaller frames due to the tight spaces near the rocker link.
    Any suggestions out there?
    bbc
    bbc is offline
    Bueno!
    Reputation: bbc's Avatar
    Check your housing length, it might be too short. Also if the sag is too low in the shock that affects the shifting as well. Adjust the shifting while riding.
    Reputation: sanjuro's Avatar
    Sep 2004
    Also trim the ends of the housing. If there is exposed inner housing, it will flex and cause ghost shifting.
    I am comfotable with the basics of cutting cables to lenght, and i am looking for more Motolite specific tips.
    run the housing over the rocker link torsion bar or under?
    Ive been working on bikes for a long time and the idea of adjusting the cable tension to coincide with sag seems like something you would see on a walmart bike.
    if that is the solution, I am very disappointed.
    Reputation: craigstr's Avatar
    Sep 2003
    Gazillion threads on this
    Do a search, there were many pictures posted about optimal cable routing. The ML is very prone to ghost shifting if the cables arent just right. I ended my problems by going with Nokon cables.
    i did a search and came up with ... not much. What key words am i lookin for?
    Any help is greatly appreciated.
    Sep 2003
    Here is a good one
    motolite cable routing confirmation please
    Here is a pic of how I have mine with the Nokon's
    Reputation: theheavyone's Avatar
    Check the derailleur hanger, even if the frame is new have it checked. If the hanger is at all out of whack it can cause shift problems.
    Reputation: anvil_den's Avatar
    Nov 2007
    Yup, check the rear dee hanger and also the main pivot for play.
    Have been running full cable without problems all these while
    full length housing.... that is an idea.
