Results 1 to 3 of 3
    Reputation: yeschiro's Avatar
    FTM Rocker reinstall question.
    So for the FTM rocker washers, there are a pair of thin ones and a pair of thicker ones.
    Which ones are for rocker/stay and which are for rocker/frame?
    Seems the easiest fit puts the thicker set rocker/frame and the thinner set rocker/stay, but wanted to verify before tightening up.
    Also looking for torque specifications for all these bolts + the shock bolt.
    Thanks.
    Your bike is not the only thing that needs maintenance!
    http://www.yeschiropractic.com
    Reputation: craigstr's Avatar
    Sep 2003
    Not sure how the washer configuration works out but the way you have it sounds logical. The FTM torque settings are posted on Shedfire, scroll down and Brant has all the frames listed.
    2012 September Shed Fire : Designing for On-One, Titus and Planet X from Calderdale.
    Reputation: Mr_Clean's Avatar
    Oct 2010
    Great! I finally found the FTM Carbon torque specs.
  1. 3D rocker Chilco
    By A MAN CALLED HORSE in forum Knolly
    Last Post: 11-13-2012, 03:51 PM
  2. How to easily take off and reinstall non-locking grips easily
    By burtonridr in forum General Discussion
    Last Post: 03-09-2012, 04:25 PM
  3. Kona Stab/Stinky rocker arm question
    By mamadirt in forum Kona
    Last Post: 02-12-2012, 10:44 AM
  4. EG Rocker question
    By Chris9702l in forum Titus
    Last Post: 10-23-2011, 08:48 PM
  5. Quick Question (Rocker arm)
    By choy30 in forum Ellsworth
    Last Post: 07-20-2011, 12:40 PM
