Results 1 to 3 of 3
    Ftm carbon rear tire.
    Easy way to shorten the trail on ftm carbon. Get some nylon washers from hardware store OD7/8 ID3/8 TH1/16. Cut one side of the washers. You don't have to remove the shock just clean the outside. Remove the air and unscrew the air chamber. Thats it. Now you can use a larger tire or a different shock without paying $100. I used 4 washers for bontrager xr 4 2.3. Make sure with the air out you bottom the suspension and check that the tire doesn't hit the frame. You can add or subtract washers. I have used it for a month and no problems to the washers.
    Attached Thumbnails Attached Thumbnails Ftm carbon rear tire.-20141020_155451_android.jpg
    Neat. So this essentially will shorten the travel of the shock as well? Is it worth the payoff?
    Yes it shortens the travel. The carbon has a spacer in the shock but its still limited in tire size or like I had a motolite shock and reduced it without paying someone to do it. To install a spacer normally you have to total disassemble shock.
  1. Replies: 60
    Last Post: 03-16-2014, 12:16 PM
  2. Force Carbon rear tire rub -- need help/advice
    By chrisingrassia in forum GT
    Last Post: 01-22-2014, 02:03 PM
  3. Replies: 20
    Last Post: 12-02-2013, 07:01 PM
  4. Meta 5.5 Carbon rear tire clearance
    By DexTan in forum Commencal
    Last Post: 11-22-2012, 07:12 PM
  5. 5.7 Carbon rear tire clearance
    By MSU Alum in forum Pivot Cycles
    Last Post: 07-05-2012, 09:54 AM
