    Mar 2006
    FTM Carbon Owners.....
    If anyone is running a 150mm RS Revelation with this frame - I would be very grateful if you could measure the HA with the fork at full extension.
    Thanks in advance
    Mar 2006
    Anyone.......?
    Mar 2012
    I did do a quick check before heading out to work - Looked like 69 - 68.5. The shock was fully extended. I measured using the bottom "Lip" on the headtube which sticks out a bit more then the top part. Hope this helps.
    -dx
    Mar 2006
    At last, thanks mate.
