Results 1 to 3 of 3
Thread: FTM brake rub
    Reputation: Mr_Clean's Avatar
    Oct 2010
    FTM brake rub
    Has anyone experienced constant brakerub on the FTM Carbon? It's running the XX groupset with standard 140mm rear discs. Bled them, aligned them, adjusted them, but sometimes it just keeps on coming back!
    Hueston Woods Trail Crew
    Reputation: Bikerbob.com's Avatar
    140 on an FTM?
    Switch back to 160 or a manly 185mm rotor.
    AND check the bolts that mount the 140 adapter to the frame. Either add washers or get shorter bolts. That is usually the culprit.
    Oct 2010
    Yes, the groupset came with a standard 140mm rear disc! Not very manly indeed! Will try swapping them for larger discs. Thanks, Bikerbob!
