Results 1 to 12 of 12
    None
    Reputation: TheHamster's Avatar
    Fox RP-23 I to I lenght Size FTM
    Can anyone tell me what size RP-23 to get for the 2010 FTM? Website lists length as 195mm but this does not translate into a size that I see offered by Fox. Any comments or help is appreciated.
    Is your frame carbon or alum.?
    None
    Frame is aluminum.
    Reputation: Vespasianus's Avatar
    I thought the ML and FTM used a 7.875 X 2.0 shock (200mm X 50mm). No?
    Aluminum frame takes a 7.875 X 2.00.
    None
    Thanks. And the size for the carbon frame is different?
    Yes, the carbon 2010 frame takes a 7.875 x 48mm.
    Quote Originally Posted by doralswheels View Post
    I don't think I ever heard of a 200X48mm shock! Very Specialized like!
    None
    Yes. That works out to 1.899....inches. Don't see them listed that way. And on the Titus site they offer the RS shock and have a selection for each frame but don't list the actual sizes.
    The Titus site is down rite now, but when it comes back up there is a shock listing for a Rock Shock Monarch RT3 rear shock for each model. There is a click on tab ( it says spec) that lists the measurement of the shock. I have both a 2010 alum. and a 2010 carbon FTM. On my carbon bike, i have ran a Fox DHL 5.0 air rear shock that is 7.875 X 2.25. I jacked the boost valve and bottom out settings way up, so the rear tire did not hit the seat tube. I have since installed the Monarch RT3 from Titus and it works great. Very easy to set up and it gives a very good ride. On my alum. FTM, i am running a 7.875 X 2.25 Fox rp23 boost valve with a #2 extra high volume air can. This gets a smile on a 68 year old rider every time i ride it. There is a fork and shock site on mtbr that tells how to limit the travel on a rp23 to get the 48mm travel amount, but i can't find it right now. Hope this helps.
    None
    Thanks for the advice. When using the 48mm travel shock, what does the total rear travel decrease to? I would also like to know what difference in ride quality is for either material. In my area I really don't need 140mm of travel. 100 to 120 is good for most of the riding around here. But I am concerned about the druability of carbon so not sure which I want more. Weight not an issue but like the looks of the carbon better.
    135mm for a 48mm travel rear shock. Mine feels alot like my 140mm travel alum FTM.
  1. Arm Lenght
    By crbrocket in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 11-10-2008, 10:55 PM
  2. what size spoke lenght?
    By scrapedknee in forum Wheels and Tires
    Last Post: 05-29-2008, 10:08 AM
  3. BB lenght for ML
    By Dominique in forum Titus
    Last Post: 08-15-2006, 12:20 PM
  4. T.T. lenght
    By DAVID J in forum Downhill - Freeride
    Last Post: 12-26-2004, 05:46 PM
  5. Spider BB size/lenght
    By amav in forum Intense
    Last Post: 04-12-2004, 12:19 AM
