The elusive El Guapo 29
Printable View
  • 12-03-2012
    brant
    Originally Posted by Fix the Spade View Post
    Serious question about completes!
    Can the suspension spec be a little more balanced than it is on the current 26er El Guapo X9? There's something blasphemous about having a CCDBa at one end, a Lyrik R at the other.
    A Monarch RT3 and Rev RLT would be a good fit, if more expensive overall than CCDB/R. There's even a 140mm 29in Sektor RL on the way. That would be masses better balanced than the EG X9's set up.
    No Lyrik 29!
    Shocks will be CCDB Air though.
  • 12-03-2012
    Fix the Spade
    Originally Posted by brant View Post
    No Lyrik 29!
    That's not what I said!
    I suggested the Rev rlt or new Sektor RL29 for the front, I know there is no Lyrik 29.
    The point I was trying to get across is that balancing a bike with a CCDB at one end and a dive-tastic R-spec fork is rubbish, better balance in dampers would be worth another 100 on the price.
  • 12-03-2012
    brant
    Gotcha.
  • 12-03-2012
    Jameswr
    Brant, is the first batch of frames going to be done 7 Jan. 2013? or starting the batch? Thanks.
  • 12-03-2012
    brant
    batch completes in taiwan on that day. Painted.
  • 12-03-2012
    Jameswr
    Sweet!
  • 01-06-2013
    bobodaclown
    excited to see these, kind of fancy a long travel 29er. Have longingly looked at the Niner WFO but can't come up with the pennies for it. Hopefully this sits close to the cost of the standard 26 EG as that would be a no brainer to get one.
    Would hen have to worry about the forks for it. yikes
  • 01-16-2013
    zonoskar
    I'm in the market for a long travel 29er. An because I owned a RacerX, Titus is high on my list. But the geometry spec has me puzzled. Brant mentions super long top tubes, but the 18" has 600mm. I ride a large (18.5") Rocky Mountain Element 29 and its top tube is 605mm and I use a 100mm stem. Based on that, I would have to go with the 625mm TT version of the El Guapo. Or am I missing something? I'm 6' tall.
    Also, the Titus website needs to be updated, I couldn't find geometry data for this bike on the site. Only in this post. And we need more color options :) although the raw would be awesome.
  • 01-16-2013
    brant
    Ah - maybe it's not so long then... Though that is on a 74.5deg seat angle - so the reach is quite long.
  • 01-24-2013
    titusquasi
    I like using Reach and Stack to size from bike to bike. Do you have a Reach number for the largest EG 29 size? Thanks for any assistance.
  • 01-25-2013
    Deerhill
    Interesting
  • 01-25-2013
    ansman
    Is the rear hub 142X12?
  • 01-25-2013
    ocean_29
    Yes, and unfortunately there s no option for 135...
  • 02-01-2013
    Velveeta
    Titanic fail... Titus hasn't come up with anything newsworthy other than a production delay since 2010... El Guapo 29? You mean the M23? It's been 3 YEARS. Come on guys... give up already.
  • 02-09-2013
    Jameswr
    I am so excited for the El Guapo 29! Any more information about rear shock? DSP, or CCDB air?
  • 02-11-2013
    budgie
    beard adds mystery...
    Somehow it has morphed into an On One and seems to be called the Codeine? Same bike or different-er? Those lads appear to have been sampling leftovers from the medicine cabinet again. Or, maybe it's just a long winter up north...
    Codeine. Proto on-one 29er FS Shed Fire : Designing for On-One, Titus and Planet X from Calderdale.
  • 02-11-2013
    Deerhill
    No seat tube brace?
    No HL.. Kind of looks like a frame mentioned earlier in the thread
  • 02-12-2013
    Fix the Spade
    Now that's a nice looking frame.
    #Edit.
    Five in travel, short stays and 67deg head angle... want, want very much.
  • 02-12-2013
    terrible
    With the clusterfck over the last version of the 26" EG it's probably not a bad idea to kill the name.
  • 02-13-2013
    brant
    Codeine is an on-one project. It's not a replacement for the EG29
  • 02-13-2013
    Smiff
    changed my mind about this, the EG29 looks just like the 26 frame, so it makes sense. wonder if the back end will be too flexible. one thing with the EG design is the seatstay attachment ends up far forward, not sure if EG29 uses same rocker, but they could make the mount wider.
    lovely mood lighting brant, hope you don't do all your engineering in the dark :p
  • 02-13-2013
    Deerhill
    hmm, am I seeing ISCG tabs?
  • 02-13-2013
    terrible
    And maybe 142 axle......
