Page 2 of 2 FirstFirst 12
Results 51 to 98 of 98
  1. #51
    Is there any news about the El guapo 29"?
  2. #52
    Reputation: terrible's Avatar
    I could really use one right now!
    "I'm the fastest of the slow guys"
  3. #53
    EG29 has taken too long and I've lost interest in it.
    Happy my my EG v2 with Slack set.
    Will probably look to get a Yt Industries bike next as their mad value.
  4. #54
    Reputation: jdcatnau's Avatar
    Feb 2007
    I can't even remember how much travel the el guapo 29" was supposed to have any more? Was it a 140 mm fork?
  5. #55
    Reputation: brant's Avatar
    140mm front, 140mm rear (actually 138, 140 and 142mm depending on size), 142mm back end using Shimano E-thru standard with our axle supplied, will work with new Shimano rear mech hanger style (available), mixer tapered headtube with 12mm upper bore, new cable routing on downtube and chainstay for rear mech and rear brake, FD over top tube (doubles as dropper guide), 25mm BB drop static, 68deg head angle, 580mm, 600mm and 625mm top tubes and 700mm, 720mm and 745mm front centre on the 16, 18, 20in models, 458mm chainstay, 190mm x 50mm shock, 73deg seat angle (actual) gives 74.5deg (effective).
    Front centre is LONG and designed for stability and lack of flop and for use with short stem (we have a 35mm model coming). Colours black (ano), white (painted), super-raw (ano).
    Completes at the factory on the 7th of January 2013.
  6. #56
    Dozer
    Reputation: yeahdog31's Avatar
    Quote Originally Posted by brant View Post
    142mm back end using Shimano E-thru standard with our axle supplied, will work with new Shimano rear mech hanger style (available).
    Too bad I can't use the 10x135 wheels I already have...
    Also, what is the story with Sram rear derailleur compatibility with this system?
  7. #57
    Reputation: craigstr's Avatar
    Sep 2003
    Thanks for the info Brant....any idea on approximate frame weight?
  8. #58
    Quote Originally Posted by yeahdog31 View Post
    hmm
    Most decent quality hubs can be swapped out of changed. Otherwise, BONUS - you have an excuse for a new wheelset.
    That said I am drawing in my head a set of converters that any machine shop could make up to make 135mm wheels work in there.
    It's not hard.
  9. #59
    Will ship with a standard (SRAM and normal Shimano) hanger.
    Funky new Shimano hanger will be an option.
    Maybe they might even ship with both if I do something wrong.
  10. #60
    Quote Originally Posted by craigstr View Post
    It will weigh what it weighs. I am not entirely sure what that is.
  11. #61
    Feb 2007
    Thanks for all the info Brant!
  12. #62
    Reputation: ocean_29's Avatar
    Mar 2012
    To bike industry .. : p
    Hope sells 2 little plastic (?) adapters for QR/15mm/20mm front for 22 euros
    Someone should take the chance and give us some overpriced Shimano like 135 qr to 142x12 adapters.
    e.g. Me, hehe, I paid around 400 euros
    For flows laced on hope 20mm front and shimano 529 rear.
    1. If I want a new similar wheel set with 142x12 back I ll need at least 650euros (all x 12 rear are currently expensive)
    2. If I just replace the rear hub I ll currently need at least 200 euros (hub rims build)
    3.if there was a little adapter I would pay for it... Do your maths, with no hussle of re build.
    Golden opportunity here, and don't be late because in a couple of years someone big (shimano ?) will sell cheaper 142x12 hubs.
    hehehe
  13. #63
  14. #64
    was surprised to read somewhere this frame may only cost £100 more than 26 EG.
    edit: that person was wrong apparently, see below!
    was expecting it to be a grand. got to factor in new wheels and fork for most of us though..
    and just got this month's Dirt today, nice article, will read properly later. i've also been in Dirt but the less said about that the better..
    my only Q about Guapo 29 is why you aren't giving it a new name as it sounds like a new bike (does it have same curvy shapes as the 26er?).. El Majo or El Lindo or something. but check with someone with better Spanish than mine (could be connotations i'm not getting hehe.)
    edit: or even El Alto (The Tall One) or El Grande (the Big One), if you want to keep it simple! since Alto doesn't seem to be taken, seems a place on the off-road cycling map in south america (near La Paz), and is a nice sly reference to certain other brand that rhymes with.. Banta Kews Wall-boy?
  15. #65
    Feb 2012
    Any idea on Pricing for the frame? What rear shock will it be spec'd with?
  16. #66
    Rear shock will be CCDB Air.
    Price TBC. Hope to keep it competitive. Of course you're getting 142 and a rear axle with this. New tooling. We'll see. Certainly the best value 140mm 29er out there. No question.
    What else is there we should be comparing to?
  17. #67
    Sep 2003
    Giant Trance X 29, Transition Bandit 29, Kona Satori, Banshee Prime, maybe the Specialized Stumpy Evo?
  18. #68
    Pricing?
  19. #69
    Feb 2012
    Thank you Brant. I am very excited. We have 4 El Guapos in the famiy. We ride them hard, and love them! In my mind it is the best all-mountain bike available at a value that can't come close to being beat by any manufacturer. I am very excited to try the 29 inch version and potentially even replace my 26 inch El Guapo as my go-to, do-it-all bike. I have no doubt that the price will not only be competetive, but unmatched. Just trying to measure how many pennies I will need to save.
    The only other bike I have really compared the El Guapo 29 to is the Transition Covert 29er, with 140mm rear wheel travel and a price of $1,700 USD (shock included). Given the two at the same price (although I expect the Titus to cost less), I would choose the Titus every time. I believe that it will be lighter, perform/ride better, and look better. Not to mention the exceptional customer service.
    In August of this year I had the opportunity to visit the Titus location in Portland, OR with my brother and cousin on a bike trip. It was fun to meet the staff there, and show off our three different El Guapo builds. The staff was very friendly and exceptionally helpful.
    Thanks for all you do!
  20. #70
    Sep 2003
    Frame/shock in the $1500 range, complete bikes in the low $3000's.
  21. #71
    ah so whoever said it was £699 (Monarch) was talking bollocks. no monarch option at all. don't believe everything you read on STW.
  22. #72
    Sep 2003
    Not the price...
    I was just answering Brant's question about prices of other 29" bikes in a similar category.
  23. #73
    Dozer
    I might include Santa Cruz Tallboy LT (aluminum) in that list.
  24. #74
    don't believe anything you hear on STW, just a bunch of audi boys that do laps of the local park on their ibis mojo's and single speeded, drop barred, fat bikes.
  25. #75
    Reputation: Fix the Spade's Avatar
    Serious question about completes!
    Can the suspension spec be a little more balanced than it is on the current 26er El Guapo X9? There's something blasphemous about having a CCDBa at one end, a Lyrik R at the other.
    A Monarch RT3 and Rev RLT would be a good fit, if more expensive overall than CCDB/R. There's even a 140mm 29in Sektor RL on the way. That would be masses better balanced than the EG X9's set up.
  26. #76
    Quote Originally Posted by Fix the Spade View Post
    No Lyrik 29!
    Shocks will be CCDB Air though.
  27. #77
    No Lyrik 29!
    That's not what I said!
    I suggested the Rev rlt or new Sektor RL29 for the front, I know there is no Lyrik 29.
    The point I was trying to get across is that balancing a bike with a CCDB at one end and a dive-tastic R-spec fork is rubbish, better balance in dampers would be worth another £100 on the price.
  28. #78
    Gotcha.
  29. #79
    Feb 2012
    Brant, is the first batch of frames going to be done 7 Jan. 2013? or starting the batch? Thanks.
  30. #80
    Quote Originally Posted by Jameswr View Post
    batch completes in taiwan on that day. Painted.
  31. #81
    Feb 2012
    Sweet!
  32. #82
    excited to see these, kind of fancy a long travel 29er. Have longingly looked at the Niner WFO but can't come up with the pennies for it. Hopefully this sits close to the cost of the standard 26 EG as that would be a no brainer to get one.
    Would hen have to worry about the forks for it. yikes
  33. #83
    Reputation: zonoskar's Avatar
    I'm in the market for a long travel 29er. An because I owned a RacerX, Titus is high on my list. But the geometry spec has me puzzled. Brant mentions super long top tubes, but the 18" has 600mm. I ride a large (18.5") Rocky Mountain Element 29 and its top tube is 605mm and I use a 100mm stem. Based on that, I would have to go with the 625mm TT version of the El Guapo. Or am I missing something? I'm 6' tall.
    Also, the Titus website needs to be updated, I couldn't find geometry data for this bike on the site. Only in this post. And we need more color options although the raw would be awesome.
  34. #84
    Quote Originally Posted by zonoskar View Post
    Ah - maybe it's not so long then... Though that is on a 74.5deg seat angle - so the reach is quite long.
  35. #85
    Reputation: titusquasi's Avatar
    I like using Reach and Stack to size from bike to bike. Do you have a Reach number for the largest EG 29 size? Thanks for any assistance.
  36. #86
    J:
    J: is offline
    Holey cow
    Reputation: J:'s Avatar
    Dec 2009
    Interesting
  37. #87
    Is the rear hub 142X12?
  38. #88
    Mar 2012
    Quote Originally Posted by ansman View Post
    Yes, and unfortunately there s no option for 135...
  39. #89
    Titanic fail... Titus hasn't come up with anything newsworthy other than a production delay since 2010... El Guapo 29? You mean the M23? It's been 3 YEARS. Come on guys... give up already.
  40. #90
    Feb 2012
    I am so excited for the El Guapo 29! Any more information about rear shock? DSP, or CCDB air?
  41. #91
    screamer
    Reputation: budgie's Avatar
    beard adds mystery...
    Somehow it has morphed into an On One and seems to be called the Codeine? Same bike or different-er? Those lads appear to have been sampling leftovers from the medicine cabinet again. Or, maybe it's just a long winter up north...
    » Codeine. Proto on-one 29er FS Shed Fire : Designing for On-One, Titus and Planet X from Calderdale.
    On heavy rotation: White Lung: Deep Fantasy
  42. #92
    J:
    J: is offline
    Holey cow
    Dec 2009
    No seat tube brace?
    No HL.. Kind of looks like a frame mentioned earlier in the thread
  43. #93
    Now that's a nice looking frame.
    #Edit.
    Five in travel, short stays and 67deg head angle... want, want very much.
  44. #94
    With the clusterfck over the last version of the 26" EG it's probably not a bad idea to kill the name.
  45. #95
    Quote Originally Posted by budgie View Post
    Codeine is an on-one project. It's not a replacement for the EG29
  46. #96
    Quote Originally Posted by terrible View Post
    changed my mind about this, the EG29 looks just like the 26 frame, so it makes sense. wonder if the back end will be too flexible. one thing with the EG design is the seatstay attachment ends up far forward, not sure if EG29 uses same rocker, but they could make the mount wider.
    lovely mood lighting brant, hope you don't do all your engineering in the dark
  47. #97
    J:
    J: is offline
    Holey cow
    Dec 2009
    hmm, am I seeing ISCG tabs?
  48. #98
    And maybe 142 axle......
