Results 1 to 3 of 3
    Shifted
    El Guapo BB/Crank Install Q?
    Installing some Shimano LX Cranks into an 09 El Guapo frame and I'm wondering on what side do I install the BB spacer? It looks as if I only need one spacer (have new Cranks + BB comes with 3 spacers) Currently I did a 1/2way, un-torqued install and I put one on the drive side. I'm thinking that's not right so before I take it off and reassemble, I thought I'd ask here first.. .
    Thanks in advance
    back at it
    2014 Trek Stache 7.
    Spacer shall be on the side where the chain is.
    /H
    Quote Originally Posted by berny2435
    Thanks in advance
    As per shimano's instructions, you put one 2.5mm spacer on the drive side for a 73mm bb shell (which is what the EG has).
