Results 1 to 7 of 7
    EG - RS Lyrik 170 a good match
    I am thinking of getting an RS Lyrik 170 solo air for my EG . . . any thoughts if if would be a good match for the EG?
    Trophy Husband
    Reputation: geolover's Avatar
    Quote Originally Posted by JTBAZ
    That is the perfect fork for that frame, IMO.
    Extreme stationary biker.
    Reputation: terrible's Avatar
    Intresting, thought they where spec'd with a 160 fork? How much would that theoretically slacken the head tube?
    "I'm the fastest of the slow guys"
    Trophy Husband
    Quote Originally Posted by terrible
    Titus was designed by/for leg-shaved, lycra-clad, mangina born little boys that cried and whined whenever a head angle decreased below 74.5 degrees. A little extra slackening couldn't hurt in this application.
    In my opinion of course.
    BTW, 10mm would be less than .5 degree.
    "El Whatever"
    Reputation: Warp's Avatar
    Quote Originally Posted by geolover
    And if that doesn't work, then just slap a 10mm spacer under the air piston of the Solo Air and Voila! you have a "proper" 160mm fork on your EG. Remove for hairy days.
    Heck... actually you could insert a spacer of 70mm and run it at 100mm travel and get that sweet 74.5 degree angle you've always dreamed of. No joke.
    Lyrik Solo Air is a no-brainer on the EG. Unless you prefer Coil. Then a Coil U-Turn.
    Check my Site
    ಠ_ಠ
    Reputation: dulyebr's Avatar
    make sure DH RC2 version. I'm loving my the DH dampers on my Lyrik - huge improvement.
    "No Clue Crew"
    Reputation: Grave9's Avatar
    That's my exact setup and I love it!............Drew
    <iframe src="http://player.vimeo.com/video/16449918?byline=0&amp;portrait=0&amp;color=05ebf7" width="580" height="326" frameborder="0"></iframe><p><a href="http://vimeo.com/16449918">"NO CLUE CREW" - SoMo (10/28/2010)</a> from <a href="http://vimeo.com/user3585697">Drew Hutchinson</a> on <a href="http://vimeo.com">Vimeo</a>.</p><p>3 Dudes with No Clue out on a Mountain............Drew</p>
