Results 1 to 2 of 2
Thread: EG Cable Rub
    Master of None
    Reputation: presslab's Avatar
    EG Cable Rub
    I recently built up a 2010 EG frame. I noticed where the two cables go from the front triangle to the seat stays the cable has a tendancy to rub the top tube. I put some 3M "helicopter tape" in this location. I also put a strip on the down tube for rock protection.
    Is this good enough? Any other recommendations for rub protection?
    Reputation: anvil_den's Avatar
    Nov 2007
    Yea any cables that run past the side of the seat tube tends to rub..realize mine too late.
    now its taped + an old rubber noodly thing cannibalized from old vee brake slotted over the cable housing. If u use adjustable seatpost with remote cable--those will rub too. I run that outside of the deraileur cable housing and bunch all 4 underneath the top tube with cable ties/velcro.
