Results 1 to 7 of 7
Thread: EG Build Specs
    EG Build Specs
    Anyone know the following figures:
    Seattube Outside Diameter - for Front D and Seatpost clamp
    Seattube Inside Diameter - have a gravity dropper so I need a shim
    Type of Front Derailleur - ?
    Torque Settings
    Shock to Rocker - ?
    Shock to Frame - ?
    Pivot Bolts at Rocker - ?
    Main Pivot - ?
    Horst Link - ?
    Derailleur Hanger - ?
    Trophy Husband
    Reputation: geolover's Avatar
    Quote Originally Posted by Chris9702l
    Taken from Bikerbob's Facebook page:
    2009/2010 FTM, X, El Guapo, Rockstar- 30.9 seatpost, 34.9 clamp, 34.9 front derailleur.
    Extreme stationary biker.
    moar alike..
    Reputation: Deerhill's Avatar
    Dec 2009
    Torque= same as the moto
    Reputation: anvil_den's Avatar
    Nov 2007
    Shim, you need a 30.9 to 27.2 for the GD.
    Front dee, need a downswing (cage lower than the clamp). I tried with the other type-- it hits the part behind the main pivot when at granny position.
    Thanks, same thing as the Moto. Still got my sheet on that. Also found the shock mounting is 21.8mm for a 2010.
    Nov 2007
    if u are going for after market shock mounting.... many list theirs as 22mm
    THats fine too... the hardware will fit without problem.
    Post the build
    "El Whatever"
    Reputation: Warp's Avatar
    Dang, those discounted EG's are sooooo tempting!
    Check my Site
