Results 1 to 13 of 13
    E13 DRS + Raceface Cranks on EG = Grinding
    I've finally got my EG built up a month ago but is having a hard time trying to get the cranks and chain guide setup right.
    It appears that the ISCG tab is welded a little too far out on causing the chain guide to sit a little too close to the cranks. Currently the bolts on the granny ring will grind against the chain guide bolts and the chain will also be touching the back plate of the chain guide when on the granny ring.
    I have already adjusted the chainline by placing all spacers on the drive side so the drive side cranks are as far out as possible but they are still rubbing. I am going to try filing down the chainring and ISCG bolts next to see whether that would help with the grinding.
    Is anyone else experiencing the same problem using the same combo of parts?
    Reputation: anvil_den's Avatar
    Nov 2007
    Don't think its a reported "known" problem but yes I do find that it is a little too far out when compared with other frames
    Had the DRS and now the Blackspire stinger-- both with same rubbing issue even when drive side shimmed to 4mm of spacers (that's about the max as anymore and the non-drive side will not be getting enuf threads to tighten it down).
    Guess I'll just have to start grinding down the bolts then.
    Reputation: craigstr's Avatar
    Sep 2003
    I had the same issue
    I was trying to put a Stinger on with RF Atlas cranks and the small ring bolts always rubbed, My first frame's ISCG tab was welded on noticeably crooked and Titus sent me a new frame (before the bankruptcy). ISCG standard says they can mount the tab flush with the bb shell or recess it 2.5mm, recessing it would be much better as you can always shim out your chainguide. I have since mounted a MRP XCG and Stinger on my frame with a X9 2x10 crank with zero issues. I think the problem could be specific to RF cranks.
    what's that rattle?
    Reputation: Blofeld's Avatar
    Face The Tabs
    I had a Socom with crooked ISCG tabs that made it impossible to set up the chainguide properly. Intense wasn't up for a replacement or repair, so I found a shop with a HammerSchmidt installation set, which includes a ISCG tab facing tool. If you can track one down, you'll likely have better results than with a file - crooked tabs are more difficult to deal with than offset tabs.
    Nov 2007
    Stinger was rubbing on xt small ring bolt too
    Quote Originally Posted by craigstr View Post
    Most noticeable for mine was on the forward most bolt of the chain guide rubbing the bolts on the granny.. and this was after an additional 1.5mm of spacers. Had to swap that out with the flatter bolt that came with the E13 DRS.
    Quote Originally Posted by Blofeld View Post
    Thanks, I am gonna ask my LBS about that.
    Yup, had the same problem here. Blackspire stinger w xt cranks 24x34 chainrings. Spacers on the bb inbetween the frame and bb will work but will result in misaligned chainline and increase wear and tear on bb.
    This is a common problem for many bikes unfortunatley and titus is not alone, although one should not see this problem on a high end bike. I contrast this with my v-tach which required a whack of spacers on the chaingiude and chainring to work with a totally weird chain line: but it works fine.
    Best solution it to grind both the chainring and chainguide bolts. Takes a few minutes but it works great. No problems after two months.
    No ISCG facing tool at the lbs.
    Ended up blowing $200 to order one. Should be arriving the end of this week.
    what's that rattle?
    Quote Originally Posted by mgv101 View Post
    Not too bad of a deal, really. I paid my LBS $70 for the privilege of having them face my BB shell down to 70.5mm.
    Just had the tabs faced. It fits perfectly now
    Mar 2011
    Woah.... I'm about to commit into a Gamut P30 Dual guide.... Dang that sounds shitty! Anybody tried the Gamut on the EG?
    I have the same problem on my 08EG with ISCG adapter plate and E13 chainguide, as well as a MRP bb bashguard on a FTM. After numerous attempts grinding and filing my RF carbon cranks I have come to the conclusion it is the RF crankset that sits too close to the frame due to the extra narrow BB cups.
    RF had provided me a solution of placing washers between the spindle and nondrive side arm to allow running more spacers behind the drive side bb cup. I have yet to do this and have since ordered E13 cranks.
  1. vpfree and raceface cranks
    By motoben1 in forum Santa Cruz
    Last Post: 03-25-2010, 02:19 AM
  2. Truvativ / FSA / RaceFace Cranks?
    By mtb.mick in forum Singlespeed
    Last Post: 07-21-2008, 03:08 PM
  3. Raceface cranks
    By Skrunk in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 05-12-2008, 12:08 PM
  4. RaceFace cranks, which rings fit?
    By ryan123 in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 09-24-2004, 10:20 PM
  5. new RaceFace X-type cranks: available when?
    By gkd in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 03-30-2004, 12:45 PM
