Results 1 to 38 of 38
Thread: Dented my ML
    MTB aficionado
    Bonking ... not feelin' well Dented my ML
    Question about a dent on my ML, but first let me explain.
    This past weekend I put a dent on my ML downtube. Here's how it happened:
    1) Rear tire picks up large rock while halling arse down hill.
    2) Rock on tire accelerates and is flung off tire at or near BB area.
    3) Rock is so big it then gets lodged between downtube and small chainring.
    4) Push on pedal and crank wouldn't move because rock is stuck inbetween downtube and small chainring.
    5) Stop to assess and then realize the rock jam and subsequent dent on downtube just above the BB/downtube weld on the driveside.
    Bad luck I guess.
    The dent is small(ish) and it cracked the paint pretty good. Should I be worried about this? What should I look for to see if a stress riser is developing?
    Thanks,
    EndUser
    My advice and $3 will buy you nothing more than a tunafish sandwich
    ಠ_ಠ
    Reputation: dulyebr's Avatar
    picture?
    searcher
    Reputation: kovi's Avatar
    Yeah, Picture?
    Kovi
    "El Whatever"
    Reputation: Warp's Avatar
    rzozaya has an identical dent. Weird to happen on any bike... and now two ML's! Hyperweird.
    I would say don't sweat it, but consult it with Titus. Maybe you two guys have a case going.
    I think the dent is at a neutral stress area... but not 100% as for neutral to torque input from the pedals. But I think it's a neutral stress area.
    Check my Site
    sushi lover
    some pics would help
    Reputation: demo_slug's Avatar
    Jan 2005
    see how much a crash replacement in Ti costs....
    this happens to MTBs.. the damage is done. just keep an eye on it.
    probably the only issue will be a reduction in resale value.
    I have a gouge out of my seat tube where the brake cable almost cut thru the seat tube. mud + bad cable routing. I sent chris a picture and he said it was good to go
    Jan 2005
    anybody seen black agness?
    thats right living legend
    Reputation: blackagness's Avatar
    Mar 2005
    Quote Originally Posted by demo_slug
    I've got the same gouge. Just chalked t up to what Demo said. We haven't seen a pic yet, but I'd be willing to bet "err kinda" that if it were something bad you wouldnt have had to ask. I mean it was from a flying/stuck rock, it's not like you launched it riderless into a rock garden where it slammed down on the downtube... but anyway if ya can I'd feel more confident with a pic.
    Unless your ML is white of course, then your in real trouble "he he"...
    MTB aficionado
    Oh No
    Quote Originally Posted by blackagness
    I'm totally focked then.
    I'll try to get a good picture of it so ya'll can see.
    Regards,
    EndUser
    Jan 2005
    Quote Originally Posted by EndUser
    Regards,
    EndUser
    downtube injurys are nothing. the down tube is mostly in tension. have your ever seen the "sling shot" bikes? the down tube is replaced with a cable...
    Ti is addictive
    Reputation: TiEndo's Avatar
    Stupid question, but is the downtube of the motolite the same as the one on the Racer-X?
    (ie triple butted hydroformed downtube?)
    "El Whatever"
    Quote Originally Posted by TiEndo
    Yes, pretty similar.
    Check my Site
    Mar 2005
    Here I Am!
    I was away for the weekend at a wacky little place called Fripp Island SC. All flat, no riding that I'd be interested in.
    Now back to the buisness at hand, "hopefully" putting Endusers minde at ease...
    If I'm not mistaken the downtube on the ML is bigger than the one on the RX.
    Jan 2005
    Quote Originally Posted by Warp
    I was cruzing along my favorite trail on sunday and a jellow jacket got sucked into my helmet. he was not happy. before he found the escape rout out of my full face helmet he stung me on the lower eyelid. today Its all puffy, I look like I got a shiner.
    MTB aficionado
    Picture(s)
    By popular demand.....
    What I suspect is the very wide bi-ovalized tube provides for a small clearance between the downtube and the smallest chainring. I have this same configuration on my Litespeed HT frame but the tubing is not oversized like the Titus. Also, I think the dent was cause by me while trying to pedal not the rock hitting the tube. The rock was jammed in there pretty good and required me to pry it out of there with a stick
    Take a look and let me know what you think.
    Thanks all,
    EndUser
    sushi lover
    to be perfectly honest, it doesn't look good... it's right where cracks would normally appear at the down tube / bottom bracket -- above the weld
    have you tried contacting Titus or your LBS?
    MTB aficionado
    No I have not.
    Quote Originally Posted by hamachi
    I'm assuming the radial cracks are limited to the paint due the deflection of the tubing. I have to admit the dent concerns me also given this is the weak spot due to the welding process. I'm going to bring it in to my local dealer and get his opinion.
    This sucks.
    Thanks for the opinion.
    EndUser
    Mar 2005
    This sucks.
    EndUser
    Yeah my small brain somehow managed to gather what you were talking about with the pedal force rock bla bla bla.
    Never the less I don't realy like the look of the cracks in the paint climbing up along the weld. I know it scratched the paint with the rock... But aside from that.
    Good call taking her by the LBS...
    MTB aficionado
    Well I don't know what he'll say...
    but the dent and cracks are very, very small. I've seen people riding with a lot worse but I just don't know if the cracks are indicative of a structural failure or just the paint cracking under flexs. The photos are sort of misleading since there is no scale. The affected area is about 8-10mm and the dent is very subtle.
    I'm going to take it in tomorrow.
    Thanks.
    EndUser
    Jan 2005
    Thanks all,
    EndUser
    wow....
    yeah given 4 more years of riding it will break right there. seriously the cracked paint makes it look bad.
    just a recommendation, sand the area and put some touch up paint over it. not as a cosmetic fix, but so you can inspect the area for cracks down the road.
    send the photo to Chris. why ask the shop? if they say its done are you going to trust them? if they say its fine will you feel better?
    Mar 2005
    Yeah...
    Thanks.
    EndUser
    I actually thought after posting, how small that ding probably looks scaled to the entire bike. Probably shouldn't have tryed to alarm ya. I'd actually trust your opinion over my own anyway..
    Mar 2005
    But Dude!!!
    wow....
    What if more of the paint chips off... New thread.
    MTB aficionado
    Demo...
    You get the best idea award. Seriously, this is a great idea. I'm going to do exactly what you recommend to monitor the area for structural problems. I could care less about what it looks like after the fact.
    Thanks,
    EndUser
    Jan 2005
    Thanks,
    EndUser
    actually i don't know it the paint will stick. might have to etch it. lime juice maybe? then a shot of tequilla...
    Reputation: AkDave's Avatar
    Bonking ... not feelin' well Ride it!!!!!
    Thanks.
    EndUser
    Rick will probably say ride it.......Your choices are limited anyway. Ride it or buy a new ft triangle....keep an eye on it and ride.
    Dave
    Idaho Transplant (closet roadie)
    Bike to the Bone...
    Reputation: rzozaya1969's Avatar
    Thanks all,
    EndUser
    My dent is a little bit further from the welds. I would take a pic, but I'm out of the country for 2 weeks, so I can't post pics. I would say send the pic to Titus and see what they say. I will do it as I get back.
    "El Whatever"
    Quote Originally Posted by AkDave
    Dave
    Very true.... I don't think it would be covered by the warranty.
    I mean, who's fault is it? Manufacturing defect? Don't think so. Owner's fault? Neither.
    If indeed I would be on my own on this issue, I would just ride the thing, hope for the best and whenever it breaks, call for a Crash Replacement.
    A pure case of bad luck, I'd say. Big bummer.
    Check my Site
    K n e e m o i
    Reputation: Daffunda's Avatar
    Aug 2005
    Another reason not to get a carbon bike. If this had happened on the Yeti ASR-SL or Carbon Epic, bye bye frame...
    "Prison sports are really fun. I get used as a frisbee, a dartboard, and a second base!" - Kneemoi
    Reputation: DaveX's Avatar
    Apparently you can get carbon frames repaired.
    Check it out---> http://www.calfeedesign.com/howtosendrepair.htm
    Eyes:blue. Knuckles:white
    Reputation: stuartie's Avatar
    Bad luck I guess.
    Thanks,
    EndUser
    Bummer...
    I'm paranoid about dents and dings on my ML and I'm not sure I'm being rational about it or if I'm being precious because it cost SOOO much money. A friend spent the same money on a Spec. Stumpjumper Pro at the same time as I got my ML and had put a pretty big dent in one of the seat stays within a couple of months. He just shrugged it off and somehow it just didn't look that bad because it is on an anodised frame. It seems that the paint damage makes the dent look worse than it really is. Both frames are made of the same material (though probably different alloy mix), and probably have the same tube thicknesses. I don't know which part of the frame is most susceptible to stress, though I guess the downtube is butted to make it as strong as possible at the BB junction - doesn't help peace-of-mind that it sounds like a coke can when you tap it with a fingernail.
    It would be good to get some data on just how strong the Titus tubing actually is...
    Mar 2005
    Quote Originally Posted by stuartie
    Bummer...
    Just how many broke Titus's have we seen here... One hand if that.
    Good point, but I just love numbers...
    "El Whatever"
    There was this Switchblade (owned by Chronos), that broke at 3 or 4 places, but nowhere near the BB, if that matters.
    The downtube on the SB is not formed, hence not subject to this issue, but not as strong.
    Check my Site
    MTB aficionado
    Hello Dave
    Dave
    Nice to hear from you Dave. Thanks for chiming in. I'm just about to leave and beat the crap out of my ML up and back to Rabbit Lake. I'm going to ride it alright.
    In addition, I got a cool note back from Titus and they said not to worry, but just keep an eye on it. Believe it or not this is my first Aluminum frame and my comfort factor is not there yet. If this was one of my old steel or Ti frames I wouldn't bat an eye. Frankly, I'm more concerned about my safety than what I spent on the frame.
    As Demo suggested... I'm going to put some touch up paint on it and just monitor it.
    I'm going riding.... dent be damn'd.
    Thanks to all for responding.
    Regards,
    EndUser
    Jan 2005
    the 05 SB is
    "El Whatever"
    EndUser
    Man, what happened to good ole steel?
    Check my Site
    Mar 2005
    And your point?
    One 5-6 year old SB that had spent alot of time in Moab, that had just been hucked mabye 5' to flat, for no telling the how many...ith time in that 5-6 yrs. Man what a piece of junk!!!
    "El Whatever"
    And your point?
    My point is that Titus downtubes at the BB area... my guess is that the frame will survive with the dent there.
    Check my Site
