Results 1 to 11 of 11
Thread: damage advice
    Feb 2013
    damage advice
    Hi everybody. I am new to this forum altho have been an avid viewer for over a year. I am looking for little advice regarding some damage i have managed to inflict on my beloved el g. A couple of weeks ago during a downhill run i managed to have a little "off" (pesky wet roots!). I brushed myself down and carried on. Next ride the bike started making some peculiar noises and next thing the gear hanger decided to snap in two depositing the deraileur into the back wheel (mangled but wheel ok luckily). I have just replaced the hanger and deraileur but have also noticed some damage to the drop out (see pics). What do you think ok to ride / or do you think its time for a new
    seat stay. PITA as its only a few mnths old. Note the silver line is sharpie i have drawn on to check if the bend becomes a crack and / or progresses. I am going to contact on-one to see what they think but would be interested in your thoughts also. Cheers R
    Reputation: craigstr's Avatar
    Sep 2003
    I did that exact same thing to my V1 El Guapo, that picture looks exactly the same as mine did. I rode it for another year before I sold it with zero problems. If you do want to replace it, seatstays are not too expensive.
    Feb 2013
    Many thanks for the speedy reply. I am of the same opinion but am erring on the side of caution.I have sent a message to on one technical dept to guage their opinion and will post with their reply. Hopefully they will agree also. I cannot believe it , my shiny new steed and i have scarred her already!!.
    Reputation: shiggy's Avatar
    Dec 1998
    damage advice
    Quote Originally Posted by hooterreh View Post
    That is not a structural problem.
    Do make sure your chain is long enough. At full compression there is ~20mm gain in chainstay length.
    mtbtires.com
    Feb 2013
    I think the chain should be ok as it had been on lots of rides with no issues. However you have me thinking i should double check. Am i correct that the chain should go around the largest chainring and largest cassette ring + 2 links (with suspension fully compressed) .
    Sep 2003
    I didnt have my chain too short but my b tension set too close to the big cog. I was climbing and hit a compression and the pulley hit the big cog and ripped the rear derailleur off, mine happened about 2 miles into its maiden voyage. Broken derailleur, twisted chain, three broken spokes on a brand new bike. Live and learn.
    J:
    J: is offline
    no E:
    Reputation: J:'s Avatar
    Dec 2009
    Could be a bit of cross chain but you will be safe for sure. Another thing to check while you're cycling the suspension is the housing/cable routing and length while it extends. It could yank the d into the spokes if it's short, or if the routing causes a bind while sus rebounds
    Reputation: anvil_den's Avatar
    Nov 2007
    Not all hangers are created equal....
    Mine on my older EG (09 which i think qualifies as "V1") is in worse shape and the its just 2 months shy of 4 yrs of regular usage. Happened when my first hanger broke after a crash ~2yrs ago and not only is the rear bit lifted up but there is a distinct gap between the frame and hanger.
    Had some hanger issues after that-- they keep bending or breaking. Until I went with the ones made by NSB-- no problems until now.
    For comparison I also have a 2nd EG and the stock hanger seems to be a different and closer in material and stiffness to the NSB ones...
    J:
    J: is offline
    no E:
    Dec 2009
    Quote Originally Posted by anvil_den View Post
    I notice the difference, still have one the old black hangers in the bin. Notice it on the newer AL rocker bolts too. Just repacked bearings and didn't have any problems like before. Still gets a softer knocking sound when unscrewing, nothing like the cracking sound fx with those older "butter" bolts.
    Nov 2007
    BTW another EG rider told me there is a diff in the hangers. The new ones available as spares places the rear dee in a slightly diff position. Forward and a tad lower which makes sense to me..given that some folks were having problems of the top jock hitting a 36 cog even when the b-screw is maxed out on certain frame.
    Dunno about the V3 stock hangers now-- this was a V2 frame, stock hanger is the same as the V1s
    Feb 2013
    That actually makes a lot of sense. Even with the b limit screw at max i cannot get as close as i would like . Currently about 10mm away (i think sram specify about 6mm). Not had any problems with skipping etc (famous last words?) so guess it should be ok.
