Results 1 to 5 of 5
    "Clunking" noise coming from rear suspension On Motolite
    I have had my ML for about a year and a half. I ride mostly XC (aggressive) and occasionally through in a drop or two (3-5 feet). I noticed yesterday that when I lift the rear wheel and let it drop that there is some play in the area around where the lower part of the rear shock attaches to the bolt. What is causing this? Is it a worn bushing, etc..? Can this be fixed, and how do I do it?
    thanks for any insight
    Blake
    Reputation: Salty 1's Avatar
    Mar 2006
    Yes your shock bush is worn.
    Easy and cheap fix at your LBS!
    Ti Steve
    Trophy Husband
    Reputation: geolover's Avatar
    Take your shock off the bike. Take the shock into the LBS and have them replace your DU bushings. They are about $3 a piece and they can do it in less than 5 minutes.
    Go home and replace shock.
    Serve and enjoy.
    Extreme stationary biker.
    Thanks for the help
    You
    thats right living legend
    Reputation: blackagness's Avatar
    Mar 2005
    or if there is some compliction with obtaining them in a timley enough manner, just tape em.
    Can't stop, Won't stop.
