Results 1 to 9 of 9
    Trail Tire TV on blogger
    Reputation: thomllama's Avatar
    Oct 2007
    Chain hitting pivot joint on Rockstar 29er
    so helping a friend build a rockstar 29er frame, went and installed the rear derailleur and when in the 11 or 12 tooth rings on the cassette the chain is hitting the pivot joint on the chai stay..
    I can back the B screw WAYYY out and almost get it clear but them it's too far out and the chain will skip... any ideas?
    Going to try and bring Trail Tire TV back. go take a look... http://trailtiretv.blogspot.com/
    Oct 2007
    images
    Attached Thumbnails Attached Thumbnails Chain hitting pivot joint on Rockstar 29er-hit1.jpg
    Reputation: shiggy's Avatar
    Dec 1998
    Quote Originally Posted by thomllama View Post
    What chainrings are you using/ which ring is the chain on in the pic?
    mtbtires.com
    Oct 2007
    Quote Originally Posted by shiggy View Post
    chain rings wont matter, but it's a XTR 960.. in the middle at the time but does it in all of them.. at the picture it's still 3 rings up the cassette.. (14 tooth?)
    alspo tried an X0 Derailluer and it was worse even
    Reputation: craigstr's Avatar
    Sep 2003
    Long cage, medium cage, or short cage derailleur? Possibly you have too much chain? I have found that in the small chainring/small cog combo the chain will hit on the V2 even with the B tension set correctly but I never use that combo anyway.
    Oct 2007
    Quote Originally Posted by craigstr View Post
    again, doesn't matter, but it's a long cage... chain length, cage length, all that stuff has no bearing on the upper jockey wheel position, just the lower... but the chain is sized properly
    standard 11-34, 9 speed cassette, regular 22-32-42 triple crank rings.. nothing out of the ordinary here
    I always do all my initial setup with the front on the middle chain ring.. I wouldn't do Small-Small either..
    what I find really odd is if you look at the first image.. the chain is still up on the third ring, when down on the 11 or 12 it's literally behind the actual seat stay (the white part) I just can't see the chain NOT hitting it during normal use.. it's a really poor design from what I can see... The derailleur kinda sits up way higher in relation to the cassette/axle than any other bike I've ever seen.. even if I could get it to clear it seems that when on the smaller gears on the cassette there would only be 3-4 teeth engaging the chain. can see that snapping the chain or the teeth off the cassette...
    Sep 2003
    Just trying to help you out
    If the B tension screw is set incorrectly and the chain is too long then it could be a problem because I have had the issue on few different bikes. I think you can add some B tension and get it to work. Here are pics of the V2 in the small cog and large cog. In both pics the chain is on the big ring (39) of an XO 2x10 setup.
    Attached Thumbnails Attached Thumbnails Chain hitting pivot joint on Rockstar 29er-p1020944.jpg
    Check your rear derailleur mounting to make sure the spring stop is resting on the derailleur mount tab. Also try loosing the rear derailleur mounting bolt and turn the derailleur counter clockways about a 1/4" and tighten the mounting bolt. I had this same trouble with a early intense 5.5 and this worked.
    Oct 2007
    Quote Originally Posted by doralswheels View Post
    that was the first thing I checked.. also made sure that the springs and such were all wound correctly. the X0 is brand spanking new so there's nothing there set wrong.. but I checked it
    ummm from the 2nd photo, the B screw is set tooo far off ... tooth to tooth should be 5-6mm from the jockey to the large ring of the cassette, and Sram's are pretty sensitive to B screw adj.
    He did take it home and finished the build with the B set just out like you're image, it's at 11MM tooth to tooth.. he says it rides/works OK, but honestly, not something I recommend as even the very slightest twist to the derailleur hanger and you could get chain in spokes when up on the grannie gear
