Results 1 to 5 of 5
    Can I run 120mm fork on racer x frame?
    As the title asks. Is 120mm on a racer x frame a good idea?
    Follow me on Twitter @OnOneCarbon456
    Hi I'am an On-One Carbon 456 mountain bike, follow me to find out what i get up to...
    Jun 2013
    You don't specify what year frame you have, but you'd have to check to see if it's specified as being able to accept the extra travel (it's not much but check),as it might void the warranty if it doesn't specify it. If it's acceptable by Titus, than see how changing the geometry might affect the ride for its intended purpose. I like the extra travel and the slightly slacker head angle, so I went for it on my Rockstar build.
    I ran one on my old racer x - but I don't think it really made the frame all it was intended to be and do. It was a touch more twitchy (which is not necessarily all related to the fork), and I felt that the front end had a tendency to lift on the steep stuff. I would just run a 100mm on it. I don't think you will see a big benefit out of the 20mm difference. But then again, this is my 2c.
    Independent Fabrications Steel Deluxe 29 SS
    Salsa El Mariachi Steel SS
    Bike Addiction
    Reputation: 00sable's Avatar
    Same as titusracer here. I did like the extra travel in the downhill rough but nothing else about it. Swapped back to the 100mm after one ride.
    Disclaimer: Always get a second opinion cause I'm just guessing
    Winning
    Jul 2013
    I think these guys hit the nail on the head.
    The Racer X 26er can take a 120mm fork, but it's geometry is designed around a 100mm XC setup.
    Many people call and email us each week asking about running longer forks on various frames, and in most instances we can comfortably say yes.
    However, when a frame is designed and intended to be a fast XC race-oriented rig, it's generally best to leaving it that way.
  1. Replies: 10
    Last Post: 08-12-2012, 11:18 PM
  2. 120mm travel fork on All Mountain frame?
    By lifanus in forum All Mountain
    Last Post: 06-26-2012, 11:21 PM
  3. Fork for Frame Optimized for 120mm Travel
    By Backnsaddleagain in forum Shocks and Suspension
    Last Post: 05-13-2011, 11:50 AM
  4. 29er Racer X, 120mm fork
    By jrahm in forum Titus
    Last Post: 04-28-2011, 04:09 AM
  5. 08 Epic Frame - 120mm Fork
    By jason8265 in forum Specialized
    Last Post: 01-11-2011, 07:43 PM
