Asylum 29er question
609 views 2 replies 3 participants last post by  sperky
#1 · (Edited)
Hey all,
So I understand the Asylum OCD 29er is a clone of the RacerX 29er. The question is, is it a clone, or is it a rebranded, relableled RacerX 29er? Is it really a Titus with a different label?
Are there any differences at all?
*edit*
Okay, I see that what Titus calls a medium is the same as Asylum's Large. Noted.
I also see that the '09 Rx29er has carbon fiber seat stays. The lighter weight is nice, but less than 100g difference (just guessing) is not that important to me.
#3 ·
I have an Asylum. It was made by Titus for Speedgoat prior to Titus having their own 29er.
The differences I can see: Sizing is different (which you already mentioned). Also, I believe the headtube angle is 70 degrees on the Asylum (Large) vs 71.5 on the Titus. The stays are not carbon on the Titus either...they are aluminum. I think the Titus might have slightly better tire clearance than the Asylum (I don't have much room left and I have Small Block 8's). Finally my large Asylum weighs 6.2lbs....I think the Titus is slightly heavier.
Hope that helps!
