Results 1 to 65 of 65
Thread: 650b El Guapo?
    650b El Guapo?
    Out of Curiosity..
    I see the MkI (assuming 08-> 09 model was MkI) listed in the 650bPalace as "650b from 26" converted List", but not sure if it applies to the latest frames for sale on Titus/On-One website.
    650B Palace: 650B from 26" Convertible List
    Has anyone tried running 650b on the 2011 El Guapo (MkII)?
    Reputation: shiggy's Avatar
    Dec 1998
    Quote Originally Posted by kfother View Post
    Out of Curiosity..
    650B does not fit in any current Titus 26" frames.
    mtbtires.com
    Reputation: anvil_den's Avatar
    Nov 2007
    .. was just looking at some Pacenti 650 rims earlier...
    Maybe just a 650 front but keep rear at 26"
    Hi
    Could there be any upgrade to the frame (like rear triangle replacement) that would fit the 650B?
    Reputation: terrible's Avatar
    No, it's been hard enough for some wanting a 142x12 rear let alone a new, longer setup for 650b. then there's the whole getting the geometry right on the front end too.
    Brant is pretty blatant about not liking the idea too.
    "I'm the fastest of the slow guys"
    Reputation: brant's Avatar
    I am almost tempted to do a run of 650b frames. I know exactly what to do geometry wise, but really feel its bandwagon jumping and almost exploitative.
    Right now the fork type supported for large 650b tyres is only Revelation which is of course the same as 29in, but at least 29ers have that extra roll over ability.
    Reputation: Deerhill's Avatar
    Dec 2009
    Dont fox/xfusion 36s work?
    Quote Originally Posted by DeerhillJ View Post
    Not interested in bodged fudged components.
    Ps: can other people see that FRS Lance Armstrong banner up there erroneously claiming he won the tour seven times? #bitofpolitics
    Dec 2009
    Fox def botched. Thought fusion specifically made the veng compatible w higher ac? If so would give me another good reason to buy one
    Registered text offender
    Dec 2011
    Quote Originally Posted by brant View Post
    I'm not against the idea of 650B wheels, but amongst the candidates for the conversion I don't see the EG being one to benifit from it. She is long and low with a good amount of travel, a true AM machine that is perfect for what she is, as she is.
    I've been seeing it for days.
    Reputation: craigstr's Avatar
    Sep 2003
    Seems like 650B is all the rage with alot of manufacturers discontinuing 26" wheels in certain models. Brant, go for it!
    yeah i think you should if it'll make money and be a good ride.
    also, might give me a reason to buy again as some small tweaks wouldn't.. #
    (you should still do the small fixes and keep 26 EG going imho at least for a few years?)
    O good lord please don't do it. I'm not even done paying for the second 26" Eg
    Unless you go making other changes how about concentraiting on the 29" EG and leaving the 650 stuff to the "us too" guys, for a little while atleast..
    Reputation: noosa2's Avatar
    Hey Brant, Don't the 650b Fox 34's and 650b WB loops forks handle pretty big tyres?
    El Guapo V3 27.5
    Out of Curiosity..
    No, but i am now building up a El Guapo v3 27.5 version. I mounted a 27.5 x 2.1 Pacenti tire on a Stans Crest rim in the rear and i have a 2013 Fox F34 160 27.5 fork on the front with a 27.5 x 2.25 Pacenti and a Stans Crest rim. Silver Chris King hubs with DT Swiss Aerolite spokes on deanoized and polished crest rims. When i am finished i will park it next to my MotoLite Ti 27.5. HiHo Silver
    Why on earth would you want an El Guapo with a 2.1in tyre?
    Dec 2009
    Impressive
    Quote Originally Posted by terrible View Post
    From that to "tempted"... while not a 180 turn, that's gotta be at least a 90
    Though I need me a 36 on EG
    and 2.4s
    screamer
    Reputation: budgie's Avatar
    Not sure 650b for the EG is the answer. What about as a way to re-launch the FTM which seems due for Brantification anyway? More in line with the upcoming/available fork and tire options. In my opinion, 650b is all about compromise in the first place, ideally aimed at people looking for one versatile bike to bridge the spectrum between 5" 26-ers (fast accelerating and nimble) and 140mm 29-ers (chunder tractors). Or to put it another way, it makes a 5" trail bike slightly more capable in the rough. The EG seems pretty well suited for its intended task (in both 26" and 29" forms) but the efforts of people to lighten theirs up for racing (craigstr?) and put 2.1 tires on the back suggests there's another segment out there, which a 650b FTM could serve well.
    5" travel, 68 degree head angle @150mm fork (67 w/slackset) & 650b, clearance for 2.3 650b tires, dropper post guides, 6ish frame + shock weight for easy build in the 27ish range without breaking the bank, bb height as appropriate... Killer!
    Hell, maybe it's just easier to make these changes to the EG & just re-badge it FTM! 6 of 1, half dozen of the other.
    On heavy rotation: White Lung: Deep Fantasy
    Dec 2009
    Quote Originally Posted by rmargoli View Post
    Hi
    I broke down last year to measure the 27.5s on my 2010 w/ 09 ss, rc4 and st has a little more clearance than cs. At the least, needs a new yoke to clear chunky middle tread and maybe little steeper st
    Dec 2011
    Quote Originally Posted by budgie View Post
    I couldn't agree more. The FTM is ripe for new stays and a perfect platform for 650B, the EG is already perfected.
    Not bad ideas at all.
    BUT! With all the negative press the aluminum FTM got I would say loose the name all together. it was a fun bike but just had too many little things wrong that added up to something that just muddy'd the name up too much.
    I still say do the above changes (650b compatability with fat tires, decent BB hights, dropper post routing, 140-150mm travel, and make it jive with a 160mm fork) and call it.......El Jefe!
    Oh and make the whole damn thing out of ALUMINUM! no facking carbon. thanks, and that is all.
    screamer
    Resurrect the Motolite
    And one more thing... Bring back the "motolite" name. That'd be great to connect to the Titus legacy, since this bike had a loyal following (myself included). The FTM was plagued with problems -- both technically and in terms of marketing -- and never really hit its stride. So a 650b re-launch would be a great way to build on past successes and differentiate it from the EG.
    Sep 2003
    I second. Bring back the Motolite.
    But that would mean I'd have to make the Chunky Monkey and Smorgasbord in a 650B size!
    screamer
    Well, with the piss-poor 650b tire selection (and I'm talking about actual availability, not hyped promises of next year's stuff), that would probably be an awesome business move. The trick is finding bikes that can accommodate those tires when caked with the mud that they were designed for.
    when I actually meet someone who has bought a 650B bike I will consider this more.
    Dozer
    Reputation: yeahdog31's Avatar
    Hard to buy one if you don't make one!
    MotoLite 650 has a nice ring to it.
    +1 on the "make it out of aluminum" comment.
    Tire size question.
    Thats the largest 27.5 tire that will fit the V3 frame.
    Quote Originally Posted by doralswheels View Post
    So why on earth would you run a 650b wheels in that case?
    The downsides if a 2.1in tyre on the rear of an El Guapo surely negate any possible benefit.
    Dec 2009
    De-anodized rims on silver kings, MK3 raw? Large?
    you have to post photo
    Paper or plastic?
    Reputation: zorg's Avatar
    Brant is holding out for the 685.34c wave that's announced for next year.
    Faster is not always better, but it's always more fun
    "El Whatever"
    Reputation: Warp's Avatar
    Agree with Brant...
    Let Titus to bring the 650B by 2014. Better a little late but get it nailed the first time and once the 650B proves that lives up to its promise... oh, and current models (V3, 29) development pays itself.
    Oh, and yes... dump the FTM. Bring back the Motolite. There's nothing wrong with aluminum.
    Check my Site
    Quote Originally Posted by Warp View Post
    +1
    Goatman
    - It's not the destination that counts but how you get there -
    Reputation: salimoneus's Avatar
    I'm still riding my '07 Motolite with a 650b up front, would love to see the model come back as a full 650b, I'd be all over it.
    How about they do a 650b rear now. Since we are all dragging our toes in the dirt.....a bigger rear wheel would be nice.
    Dec 2009
    Any 09" rear end inventory still laying around? cut those square tubes on the 09' stays little longer. I like the old stays, they ROCK solid
    I am willing to put up with 2.3 nevegals until new rubber comes out 2013 (and I don't like nev)
    I'm sure that square tube is easy to come buy. Should be super easy to cut those to length and change the angle of the interface between the seatstay bridge, chainstay yoke and fsr dropout on the rear. It'd only take a few seconds on the cnc mill and TA-DA!!!! no more stub'd toes!
    Please! I'd buy an "optional" rear triangle for 650b right now if they put it on the website. (but please sell them in the proper v3 colors)
    Nov 2007
    27.5 stays?
    Prebooking one now if its ever gonna materialize.
    Me too
    Latest Titus news letter:
    a number of new Titus frames that are going to be coming down the pipe-line - more details to follow but there was a lot of discussion about something between 26" and 29er.
    What's the titus return policy for a "lightly used" frame.....? Or should I say, "is there a trade in program like back in the day ?"
    Havn't even finished paying for the last frame yet and now the rumor of a 650b grows even bigger. Great.
    oh my... just spend a bomb for my EG and now these... savings starts now.. hopefully something really nice. keep teasing us with more info...
    Dec 2009
    Good job!
    Quote Originally Posted by anvil_den View Post
    27.5 stays?
    Sep 2003
    Great tire, been running them all season (in the 26" version).
    Nov 2007
    Vol looks good. Wonder what's the weight...
    Hans Dampf 650B on my shortlist if 27.5 ever gonna make it on the EG. This looks to be another option.
    Tried the 26' last week. definitely hooked. DHf front washed but dampf rear (trailstar compound) just kept digging and going...
    Dec 2009
    Looks like more volume in the other race'r version, but not much tread as others.
    Haven't tried the 26 or the Dampf, but yeah, like that trailstar compound too. Muddy Mary fr in front has really good life
    On griper, the centers look more chevron where others tires are ramped
    Sep 2003
    The Michelin's are very light. My 2.25 GripR in 26" was under 650 grams and the 2.1 under 600. They are tubeless ready to boot. They roll super fast for a full tread tire and the wear is excellent. My favorite tire used to be the Ardent but their tubeless issues and heavier weight made me look for something else. I think the traction the Grip R's get is 90% of what I used to get with the Ardent but with much better wear, tubeless compatibility, less rolling resistance, less weight. Cheaper too.
    Nov 2007
    Dampf weight is an 'issue' if the build is aimed to be light.
    Performance wise ,sure beat my Ardents (2.4) hands down. Was able to compare within the same day/ condition when testing out 2 builds last week...
    Ardents @ 19 front/ 21 rear psi...
    Dampf @ ~31-33 rear-- corners a lot better in the wet. I thought the center knobs were digging the soft ground a little easier... but maybe knobs on my old Ardents are a little hard by now.
    Craig, I have yet to try the Grip'r. Mich are more expensive in my part of the world. But with those full knob config, and if you say they roll well..definitely will look into them more for my race day considerations.
    Dec 2009
    These tires look very good
    Apparently Hans Dampf is already available for purchase, &'s @ 715mm!!
    Craigstr did you use/like those gripr's better on front or back?
    Sep 2003
    I use them front and rear
    Dec 2009
    How's volume on the 2.25 Grip'r? larger than DHF 2.3?
    Sep 2003
    Actually measures 2.3 and has a bit more volume then a 2.3 DHF.
    Dec 2009
    Sweet, new version looks like a good replacement for folding 2.35 dhf (thrown away too many of the small dhf from 1" sidewall tear). How are the sidewalls, you tear any?
    Vol looks good. Wonder what's the weight....
    On second look, that 650b photo is good size 2.35, thought it was 2.25. Wonder what the specs gonna be . .
    Formerly PaintPeelinPbody
    Reputation: PHeller's Avatar
    Dec 2012
    2013 Update to this topic?
    GIS/GPS Pro using ArcFM for Utility Mapping - Always willing to connect with other MTBers in the industry.
    Dec 2009
    Well that Grip'r is a great tire with good volume (thanks craigstr), it doesn't wash out at high speed like the Han Dampf..
    Grip'r lasts longer, better sidewall and is not balloon round like the HD, costs less too!
    Dec 2009
    Idea!
    el Guapo 650b + Chunky Monkey and Grip'r= Yes please
    Jan 2011
    2009 El 650b Guapo conversion: Fox RL 150 Fork, Halo Vapour 650b Wheelset with Hope Evo II hubs, Kenda Nevegal 650b 2.35 Front tire, Nevegal Slant Six 650b 2.1 Rear tire. KS dropper seatpost.650b El Guapo?-img_4264.jpg
    Jun 2013
    Well done! How different does it ride?
    Jan 2011
    Never rode it as a 26". Looked on 650b palace website and found the list of convertible frames. I then found a frame on pinkbike.com and began my build. The only problem I had was finding a rear tire that fit on the rear. Tried a few and ended up with the Slant Six. I usually ride a 29er. I started picking up parts on eBay and craiglist until I had enough parts to build the El Guapo. I rode an all-mountain 26" and wanted to try something different. I like the change up. It truly is the best of both worlds. I use the 29er (Intense Spider) for long epic rides and the El Guapo for short technical rides. The build was on a budget. Started with cheap set of wheels (syncros) I found on craigslist. Once I committed to the frame, I had a wheelset (Halo Vapour) custom built. Love the bike and built it for about $1000. Better than buying new....and I can always put some 26" if I want to go downhilling. This bike gives me many options.
    Nov 2007
    Do you have any close up pics of the tire clearance on the stays and yoke area for the rear?
    I would say there is none. Even with a large volume 26x2.35 things got tight in the mud around here.
    Why waste the time and money on the wheels for a bigger tire if you can't run anything bigger than a 2.1?
    This is why I (still) run a B6 setup on my MotoLite, with a 650b NeoMoto 2.35 up front, and a 26" Cinder 2.2 in the back. IMO most of the benefits of 650b are gained up front, and it's just not worth losing the low end gear ratio out back, at least where I ride. There's a good reason why motocross bikes run with a similar setup, it works great =)
    Jan 2011
    here you go
    More clearance when bike is weighted. Great as a trail bike, at 48 yrs old, my crazy days are close to being over. I avoid muddy days with this bike. To me it was worth the effort and the money. I buy parts, build bikes, ride for them for awhile and move on to something else and usually make all my money back. I'm a thrifty bastard and find awesome deals on craigslist, ebay, mtbr and pinkbike. I tell me wife that it could be worse...I can drink more beer and get fatter....or I can chase other hobbies like Bikes. If you're like me the best bike is the next one you're on or the one you're building.
    Dec 2009
    yup, 1/2" short shock will afford you more yoke clearance and give a needed slacker front too. STA not so much
    Question is if the new 29 CS would fit, pics they have are not very good, but yoke may give some room now. Especially if the extra inch add to the 29 rear only comes @ the new 142 dropouts
    brant still around?
    Nov 2007
    Quote Originally Posted by coacheye View Post
    If it aint for the couple of years you have over me... I would say its my long lost twin talking
    Been pushing my older EG to max out on the side of being big-- finally gone dual crown this year with the rest of geo in the right numbers... was interested to go 650 on the other EG in the house. But will come back to it in a bit -- transformation of a cardio-training singlespeed into something entirely different is taking up all my concentration these 2 months...
