    Reputation: demo_slug's Avatar
    Jan 2005
    2.6 rear tire on ML?
    broke a spoke on my ML durring hill climb tuesday. but can't miss out on hill climb thursday. so I put my supermoto wheel on my ML. good thing I run 8 inch rears on both bikes. fits fine.
    thats right living legend
    Reputation: blackagness's Avatar
    Mar 2005
    Whaaa????
    Quote Originally Posted by demo_slug
    I try'ed a Maxxis Advantage 2.4 DH on mine, and it wouldn't even budge through the seatstay bridge...what gives... Wider rims help I suppose.
    FM
    FM is offline
    Reputation: FM's Avatar
    Apr 2003
    Most excellent! I am on the hunt for new tires now, and bigger is better.
    What tire is that?
    Jan 2005
    Quote Originally Posted by FM
    What tire is that?
    I'll sell you this one for $40.... I've shaved the center lugs down thru a special 9 month process.
    god, I'm so lazy. I need to put an XC tire on there. but I'm so lazy. that tire is going to kick my arse tomorrow.
    oh yeah, it is a gazzalodi G 2.6 tubeless made by nokian.. rated PSI for the tire is 22-36 psi. super thick sidewall. only 1400grams. the only tubless tire i can run at 25 psi without folding at speed. they also make a 2.3 version.
    as a front tire they seemed to have a dead spot when you start to lean lightly into a corner, but they catch hard on the edge.. they are square.....or at least they had a dead spot until I got a fox 40.
